Chucking reamersHand reamers?
Hard to find imperial sizeAliExpress, Kijiji etc
I saw those metric reamers set, but i tried to find imperial set at low price, ...KBC example. Travers would be similar.
Results Page 1 :: KBC Tools & Machinery
www.kbctools.ca
Looks what i would like...I got some hand reamers from these guys that didn't break the bank...
KTS Tooling Supply
ktstooling.com
Compare prices, you might find KTS is expensive. (just a spot check, I didn't look in detail)Looks what i would like...
For example my next project will be to make a lathe bed stop and i want i want to have an indicator in it.Asia & Europe are predominantly metric, so you are kind of stuck with N-Am suppliers if that's what you are after.
But again depends on what you are doing. If you have a 0.250 ground shaft & want 0.0005" diametric clearance, you need a 0.2505" reamer. So it's Imperial-ish, I guess you could say decimal Imperial. But many folks think they need a 0.2500" reamer because its 1/4". My question is for what purpose? Ground pins & drill rod have +/- tolerances so it may not be good for intended purpose. Hopefully this makes sense. Trying to save you money LOL
Accusize has a decent set of 29 chucking reamers. They are not very cheap anymore but I have the same set I bought 6-8 years ago and like them. Mine are not accusize branded but the exact same set they advertise now as accusize are identical to my set.
I figure it's better to wait until I really really need them and buy exactly what I need. Having said that, I was trolling ebay round xmas time and found a semi used 7pc 1/8 - 1/2 by 1/16ths set for $20 so I snapped that up. Still haven't actually used any of them yet though, so... kinda reinforces PeterT's point...Some people like to have an over/under set so presumably could handle situations like a light press fit or a light running fit. Personally I feel its a way to burn through a lot of money without a specific purpose in mind.
Do you have ever view a video on how to do it?Make your own D bit reamer?
Ok..I had a look on YouTube.Make your own D bit reamer?
