Proper mill cutter and technique
Am I correct in assuming that the best ideal placement is to have clamp perpendicular to the T slot with the edge of the work piece right up to the edge of the T slot and the step block of the clamp right up to the other edge of the T slot?
Not really, but that is next best. Best is a full compressed column. A hole in the vise and a flat bottom so that the T-Nut compresses solid metal from top to bottom.
Ideally with the stud sticking up in the canter of the clamp so the force is equal on both sides of the T slot?
Yes, but as stated above, a full column is best. It isn't the equality of both sides. It's the need to avoid tension. Full compression is best.
Are T slots on tables generally considered to be weak or is this mostly a problem only on smaller mills?
Cast iron has poor ductility period. But it is very strong in compression. Think of it a bit like concrete.
I think I'll take the time to make drawings and provide the science behind this issue that others can critique so we can give a consensus of advice. As already noted, there is lots of discussion about it on this forum and elsewhere. Just count yourself lucky to be among those who learned about it from others rather than through experience.
I guess my big question would be if using say the longest strap clamp (please correct me if that is the wrong name) in the set and a work piece and the notched packing block positioned as far apart as possible from the T slot. So basically the worst case set up you can manage with a regular hold down set. How much force would you need to put on the stud pulling up to break the table? I am aware that the nature of threads is that they can apply extreme amounts of force. I am just curious if we are talking like pull to tight on a wrench by accident tight or 2 hands giving it all you got tight? Also how small of a diameter of stud before the stud and or threads are the weak link and not the table?
I am genuinely curious how much of this is in the numbers and how much is speculation based of off what people have seen or heard happen? What I mean is is this a common thing to happen or the results of a 200 pound gorilla trying to get every last degree of turn out of a bolt with a 2 foot snipe? For instance are the forces needed to break the T slots more than the force it would take to mar and ruin the finish on the part being clamped? If it is more then I think most people would stop tightening for fear of damaging the part. However if it is less than it is effeminately something that should always be on the mind when doing setup.
The more I think about this the more fascinated I become. This never would have occurred to me had someone not said something and I am sure it would be the same for most people starting out.
This is a very healthy mindset.
I did all the math for someone else who asked the same question earlier.
I'll take the time to find it in the process of preparing the thread I proposed earlier. In the meantime, I can at least summarize what I recall.
First of all, it's a lot more common than you might think. It happens all the time. When it does, few are willing to confess.
I'm not a career machinist. I am an accomplished Engineer. Maybe I've seen a hundred mills in my life. Probably a dozen of them had broken T-slots. It's hard to say exactly why - maybe through threaded T-Nuts, maybe poor setup. Maybe gorilla's with tools.
Quite frankly, the math is scary. If you go by the published material properties, it's really easy to pop off the edges of a T-slot. It doesn't take a gorilla to do it. In fact it's hard to believe it doesn't happen more often.
The situation is made worse by the porous nature of cast iron. Casting porosity and casting inclusions are almost a rule. So even very accurate material properties should be considered best case. In the automotive world, cast iron properties are usually derated by a factor of 5 for that very reason. Sometimes even that is simply not enough.
The situation is made even worse by the size of the standard studs used with T-Nuts. For demonstration purposes, I'll just arbitrarily select 1/2" as an average size bolt used on a mill table T-slot. Mine are 5/8. An extremely mild torque of say 10 foot pounds on a dry fastener generates a force of roughly a thousand pounds on the T-slot. This force is not distributed evenly - it gets concentrated on the ears of the slot and further exacerbated by the corner geometry which becomes a stress riser.
It's a whole lot of factors all conspiring to destroy your table. It is simply not a trivial problem that only bites a very select number of testosterone fueled gorilla's. It can and will bite the average machinist if they ignore it.
It's not if it will happen, it's only when. You ignore it at your peril.
And you are absolutely right about the fact that every new machinist is at risk. Nobody would ever think to worry about it on their own. That's exactly why I try to point it out whenever I think someone might not know.
But there is good news. As easy as it is to break a T-slot, it's just as easy to protect them. The easiest way to do that is to always keep your joints in compression. Cast iron is very strong in compression. Avoid tensile forces. @CWret made a very nice T-Nut that solves a lot of problems - it's a beautiful elegant solution. The principle can be easily extended to longer distances.
I don't actually think the worst case is a long step clamp (my name for your strap clamp). It isn't the distance. It's the tensile bending force on the cast iron ear. The bolt and nut are always in line no matter where the ends are. And the ends are almost always applying a downwards compressive force. So it's really only the torque on the bolt that matters and then only for tensile loads not compression loads.
Avoid tensile loads. Simple as that. Study @CWret's vise hold down T-nut - it shows how to span distances effectively. There are many other effective solutions too. Just be careful to avoid the problem of the bolt bottoming out which is just as dangerous.
58541-918bf4efe08487bbca06b222325498a9.webp58540-64c8caa86ce503f9867f772e675c061c.webp58543-a4b63bdfe8f3a73f7d2d9e1be82b0c4b.webp
View attachment 58491View attachment 58492View attachment 58493
Thank you I appreciate you taking the time to help me better understand this. This is a little bit of a tangent that isn't really relevant but I feel you may know the answer. Would cast steel have this same problem and if so would it be any stronger or would it be weaker? I ask out of curiosity. My background is in welding and though it has been a long time since I have done repairs on either I do remember them being quite different materials at least from a repair perspective.
My second question is about the clamps pictured. I can tell because of the angle is there a step on the left side of the bottom piece as well? I am assuming that is what the red circle indicates? As I mentioned in an earlier post I need to make some dedicated hardware to hold the vise down and this looks like it would be pretty easy and quick solution. Just want to make sure I understand it first. Would having a T section down the center still work in order to have more threads engaged? Or would that ad unwanted rigidity to the nut?
Sorry to keep hammering you with questions. I really wish I had access to an old mill table that was worn out and scrap. I would love to test different configurations and sizes of studs and see what happens.
Cast Steel has much better tensile strength than cast iron and isn't nearly as easily broken. However, it's yield strength would allow the bed to deform which isn't a good property for a mill table.
Yes. The photos are @CWret's. The red circles were mine. Both ends of his T-Nut are raised.
@CWret's method is perfect for a vise without holes for tie-down bolts.
I'm not sure what you mean?
That's funny cuz I was thinking of doing exactly the same thing for the thread I proposed. It would be subject to significant variation caused by the non-uniform material properties of cast iron. But still worth doing.
The best way I can try to describe what I mean is if you were to take a regular T-nut shape and relieve the middle of both sides where it contacts the underside of the T slots. So just like the piece in your picture it would only contact the underside at the four corners of the nut. It would just have the section still that goes up in between so the bolts would have more than just a few threads engaged. This may be completely unnecessary it just looks like the pieces are quite thin and would flex when tightening. I could also be wrong I have issues telling material thickness and sizes from pictures.
This all seems so complicated but then so far I've not yet cracked a T-Slot. As I understand it though, this photo shows the correct positioning of the hold down bolt.
While this one is worse.
Moving the hold down closer to the right would improve things with respect to the T-Slot but worsen the hold down pressure.
It's that simple isn't it?
I think you are lucky and also skilled. Your table is probably better than many, but you also have enough of a natural feel for how much torque to apply to the bolt. I don't think that is the rule and certainly not for new machinists. Most guys have no feeling for how much torque is enough and how much is too much. Now consider being a new machinist worried about parts flying across the room.
Yes, it's that simple! Nuff said.
If I understand, you are talking about a regular sized T-Nut with 4 contact corners......
Without some stress analysis software, I instinctively think that there would be a very small benefit to that. Probably not enough to save a table though.
I'm reluctant to do an armchair analysis because it would be too sketchy and perhaps too hard to follow. But many years of experience doing mechanical design in the Auto Industry in a team setting suggests I can/should at least try.
Ductile metals like steel have a stress/strain (Force/deformation) relationship that is linear and proportional. Furthermore, they have a yield strength that when exceeded results in permanent deformation first and failure much later.
Non-ductile metals have a very low stress/strain relationship and virtually no yield strength. They break instead.
The nuts and bolt are steel. As you tighten the bolt, the nuts will bend and the bolt will stretch. Bending and stretching starts immediately and will progress linearly as the bolt is tightened. At some point either before or after the yield point is reached, the nut will bend enough to contact at the bridge point. The cast iron plate above the nut will not bend significantly, it will just absorb more and more force until it reaches its lower than steel ultimate strength, and then it will suddenly break by fracturing along all of the grain boundaries. The fracture surface will look powdery with virtually no yielding evident.
In truth, I think your concept is similar to what @CWret did, except that his design extends the 4 corners out far enough to be under the compression points of the clamping elements. The result of this is that there is no bending/tension on the cast iron. Only compression. Cast iron is very strong in compression. So no failure can occur until the center of the nut bends enough to contact the bottom of the slot. Even so, it will take MUCH more force to reach the breaking point of the cast iron because the 4 compression points are still sharing the majority of the reaction load.
I think I'll stop there for fear of making the whole thing more complicated than it is.
If @PeterT or someone else equally skilled with CAD software could make some sketches for us, this would all be easier to explain.
Somebody with CAD stress analysis skills could even turn this into a great visual. Sadly, that isn't me. I can do it in Catia but I can't afford the software.
For your part, try to visualize a long nut that reaches out far enough to be under the vise, and back far enough to be under a compression pillar of some kind - like the angle section of @CWret's design.
I have a couple of sets of hold down clamp sets for my mill, both 1/2" . The nuts are flanged heavy . 1/2" heavy nuts are 7/8" instead of 3/4" . A 7/8" wrench is a fair bit longer than a 3/4" and those tightening them are machinists, not mechanics. Not that your average mechanic would have an idea of torque values , either, though they should.
like this?
-- I simplified the nut for clarity.
Yup! Exactly.
And yes, the nut could be drawn a bit thicket.
Even a non-recessed nut that extends under both compression columns is better than no compression columns at all. Picture a long rectangular nut.
PS - I didn't know you could use cad like that! LOL!
I was pretty tired when I wrote my question and probably made it quite complicated. I tend to do that :oops:
This was all I meant. mostly just because the one in the original photo looked like it might be thin and only have a thread or two engaging. But I wasn't sure if it is supposed to be thing by design. I do very much like the simplicity of this design.
And thank you Dabbler for the for the cad color graphics.
I'm a little late noticing this thread - I have very little to add to @Susquatch comments - he covered the topic very well, as he usually does. :-) Hopefully, this helps to avoid someone tearing out a chunk of their table. I have a small detail to add - from @Dabbler 's dwg - the 3 pieces of my clamp (white angle, the pink T-nut, and the blue bolt) stay together as one unit. I have 4 of these clamps, and the length of the bolts for each clamp was shortened for that specific clamp (to ensure they do not bottom out).
PS1 As an aside - one of my projects on the "to-do-list" (#59 I believe) is to build a clamp to replace the typical bar clamp (a typical clamp is pictured in @jcdammeyer post # 47above). It will be easily adjustable in location and height. It will have a sliding base that puts the T-nut in compression between the T-nut and base. It's still in my head. Maybe I'll get a chance to sketch it shortly and share the idea here.
PS2 I to call my nut a U-nut and not a T-nut.
PS3 I'm on my way to get a rolling tool chest. On sale today at Crappy Tire #058-1377-2. It will become my center for grinding. It will contain all grinding and sanding accessories plus 2 bench grinders and a home-built buffer (as well as my soon-to-arrive 42" belt sander). Happy day :-)
