Megar arc 5040dd
I made the pictured piece today to finish up my quill dro and struggled more than I should have. I very rarely have had to make pieces with a large cut out like this but have struggled when I do. I am wondering both what the proper cutter to use is as well as the proper technique. Or I guess maybe the easiest way or quickest way to do it. The material is .375" aluminum. The red line is the first cut I did with a .750 2 flute end mill. The depth of cut was the full .375". This took some playing with the speeds and my feed rate to get it to make the cut without it sounding bad but I got there. The next cut I tried to do was the blue line. At first I tried to step over .350" but it didn't like that and you could see it try to lift the part ever so slightly, I assume because so much material was gone. The part was in the vice 90 degrees from the way it is in the photo. This ended up being a good thing because I miss read the final dimension of the cut out and would have blown the part if it was able to make the cut. I reduced the step over to .150" and it made the cut but not nicely. The cutter wasn't a very sharp one I only used it hoping that the size would save me time. I swapped out the the cutter for a .500" 2 flute end mill that felt sharp. My selection of 2 flute cuter is very limited. I then tried the same thing again I believe at about .050" step over this time. it went ok but the cut looked crappy to. At this point I had about .050" left top take off each side. I decided to to 2 finishing passes climb milling the green line. The first one I did .025 step over and it looked just as crappy as before. At this point I switched to a sharp 4 flute end mill and did the same final pass climb milling with .025" step over and it cleaned up nice.
Should I have used a 4 flute end mill from the beginning? I was also thinking should I have used a much smaller cutter and just cut the U shaped perimeter? And if I did that should it have been at full depth of multiple passes at increasing depths? or should I have done what I did but not at the full .375" depth and done more passes at maybe .040" or .050"? Or did I do it the right way and it was just a case of using dull cutters? Previous times I have done similar pieces I have done it with a 12mm 4 flute carbide end mill and just slowly worked my way deeper and deeper. I was for a wrench for my collet chuck and was out of steel and took forever.
This seems like it should be a simple and fast operation.
