Precision Master Square MACHINIST TOOL, $700, London, ON
What does the handle look like? I have a 6" Cylinder square that came with a Kijiji lot I bought. No idea how a handle would work, but open to ideas.
Photos show an adjustable lever handle, I’m assuming so you can set it so that it doesn’t stick over the edge. Having a handle keeps your skin acids off the surfaces of the square and makes it easier to pick/put down straight away from the surface plate.
Fowler shows a U-shaped handle attached in two places on the end of their 22” tall square.
I think I’d rather have the wooden box as it would pick up some of the moisture rather than condensing on the plastic any thoughts? I don’t think this has ever been brought up before. Wood should last longer hinge wise.
Maybe, depends on your shop: I don’t have a rust problem in my semi-conditioned basement, but run a dehumidifier in the Winter (enough A/C in the Summer). I also put Zerust Tabs in boxes that I rarely open. I have some wooden boxes, but mostly steel & plastic.
I would agree about the hinges since the box is one-piece and the plastic hinge will eventually break. However, the hinges on most wooden boxes like those aren’t very robust (but you can replace/upgrade them).
For those that aren't in the know, you can 'prove' any cylinder square. Buying an inexpensive offshore one is just fine. The way they *have to* be made makes them provable.
What I mean by that is you set up your scratch gauge as a squareness comparator, and check it from 4 or 6 angles around the square - by rotating the cylinder square. It is easy to calibrate a cheap one to half-tenths. It doesn't matter if it is off a few tenths, as long as you document it.
