Painting a side draft hood
Cormad
New Member
Hey all,
I just had a side draft hood made at a local sheet metal shop. Do I need high heat paint (Automotive) or can I use regular metal paint ?
Jeff
Oh, painting. Novel idea. The hood itself doesn't get "particularly" hot - though it will burn you. I'd try regular primer and see how it behaves.
Hey Paul, If I don't paint it now I never will :) . Bought two rattle cans of black exhaust header paint.
I vote you paint it but only if you promise that you will never show it to any of the other members' management - especially not mine. The last thing I need is to have to start painting things.
If you ever have a fire in there you will regret not using high temp paint. On the other hand, if you ever have a fire in there, you will regret a lot of things a lot more than that!
Personally, I doubt it matters but why not! Since you already have the paint, I'd use it.
I had a welding instructor that used to say "that anything worth making was worth painting".
Paint hides a LOT of sins! LOL!
Git-R-done!
Good choice, on the high heat paint. May stink on the first heat, but should work fine!
