OTTAWA Area - Flat Taper in Mild Steel Plate
ConnorBe
New Member
Anyone in here have/know someone with a milling machine in the Ottawa area that can give me a hand?
Looking to have a flat taper cut in these alignment shims. Varying orientations/tapers for a full set. Not precision work. Not particularly time sensitive.
Will come laser cut as you see drawn in ~3mm mild steel.
Work holding via a fixture plate with bolts (maybe super glue on the edges if needed). I can dimension it for T-slot table/ huge vise, or whatever you want really. Work holding easily changed.
If interested please reach out! Thanks
Is there a reason that you can't laser cut it after milling the taper? Seems to me like you've got a whole lot of not particularly well supported details on that part after it's lasered out. If you can laser cut it after tapering it might make the milling setup a lot easier.
Is there a reason that you can't laser cut it after milling the taper? Seems to me like you've got a whole lot of not particularly well supported details on that part. If you can laser cut it after might make the milling setup a lot easier.
Outsourcing the cutting to Send Cut Send. Only $3 per unit. I agree that would be ideal though.
https://www.cutmyparts.ca/
And
https://www.readysetcut.ca/
Are both Ontario based services like send cut send. Cheaper too without cross border stuff, and exchange rates.
As for the taper that is going to be fun. I would find someone with an autofeed surface grinder and sine vice with flood coolant. I wouldn't really consider doing it another way. Would be a relatively easy job with that setup though. Would just take a while, which is why I mentioned an automatic grinder.....
And
Thanks! I'll look into those, though I've looked at them before in passing and their mild steel material selection was not comparable to Send Cut Send. Maybe things have changed now.
I thought about that exact surface grinder setup too! But taking 1mm - 1.5mm off that route would take all day. Though if someone in here has that setup I'm definitely up for it.
Doing a high feed and speed on small endmill with super shallow cut should work too if we can hold down the small areas. Again to any interested users out there, I can add support tabs/add structure anywhere on the model to reduce the hassle factor, just more for me to cut off in post processing.
Attached is what the final product needs to be, any additional tabs which i can subsequently cut off is fair game.
If anyone wants to quote me on having these cut out via cnc milling I'd also be interested, the only thing that changes is the required taper/direction. Shim profile stays the same with exception of mirroring the part for left and right sides.
Is that 169mm?
How much do you want shaved off?
Sounds like the taper is not a simple taper, but taper in more than one direction?
What accuracy do you need?
Is that 169mm?
Hi! Yes sorry should have specified - mm's
They're camber or toe shims, one taper direction per shim (only either left to right, or top to bottom). No compound tapers or anything fancy. I was thinking the fixture plate could be shimmed off the milling table to achieve the desired taper, but maybe there are smarter ways.
The maximum I would want shaved off is 1.9mm from a 3mm thick piece, with the top of the shim being the thin end.
The accuracy probably depends on how well the part can be held? If accuracy could be within .10mm I would be thrilled, but even +/-.25mm i'd be happy. It's a shim bolted between two machined surfaces, so as long as it can be fairly flat.
Would start with a couple pairs to figure things out, but I would probably want 16 - 20 shims total with each pair (left and right side) of shims being a different taper.
It's for my ruined grocery-getter. Once out of the testing phase, possibly could do a very small production run of 10 or so sets of 20 shims, but will see.
I have cnc capability so if the shim started with tabs to allow it to be held down I could just program in the change in Z, for example G1 X 6.7 Z -0.075 and use a face mill, would require several light passes with a face mill. If not in a hurry I could possibly do one pair but not interested in doing a bunch. I have a bunch of projects on the go so probably better to look for someone with more available time.
Thanks! Will see if i get lucky with another person, but if all else fails I'll circle back.
I forgot to add in the original post, but for all reading this is paid work $$
Now that I know the purpose and associated acceptable tolerance. Another way would be add some hold down tabs, and close in that bottom section and tabs to actually make it machinable. Then you could simply screw it down to a fixture plate and tilt it on the angle via sine plate. once you walk around the face and cut your angle, avoiding the hold down tabs, then just cut them off by hand. Sometimes adding a bit of extra material saves you so much headache and frustration in the end. All the extra tabs could simply be cut off with a hacksaw, or zip wheel and dressed with a file. Have those thin features tied together will make it MUCH more machinable.
Something like that perhaps. Maybe that tab on the left could be rotated to be on the bottom, and the one on the right to the top.
View attachment 64674View attachment 64674
Thanks Dan, I can 100% add tabs/structure like that wherever the machine operators specifies to make the job easy. Adding as you suggested is no extra cost and probably 20 minutes of work in CAD.
ConnorBe,
I'm curious how much camber are you running?
Interesting side story...
In my teenage years my Mustang handled like a 65 Mustang pretty lousy. I didn't have a clue about caster, camber or toe. From time to time I would pay for a front end alignment and the car never felt any better than before I went in, sometimes worse.
So I started reading about front ends and chassis design. I looked back at the little print outs showing the as found as left alignment specifications from my previous alignments on those fancy machines and was shocked the operators were clueless they did actually make things worse in some cases, and in every case the as left settings were absolutely terrible if you wanted the car to handle. A bit more reading and it turns out the published specifications for a 65 Mustang that all the alignment shops use is based on the original bias ply tires and optimized for fuel economy and ride comfort.Anybody and everybody in the know uses a completely different set of specifications. Back to the alignment shop," we can't do that we must use the published settings."
So I purchase a Longacre caster /camber gauge and start doing my alignments for free at home. Night and day difference, for the first time in my life my car has a proper alignment.
Then the chassis modifications begin, starting with the Arning A-Arm drop, bigger sway bar, Konis etc. Huge difference but you can only get so far with the Shelby approach. So upgrade to R&P, full on TCP kit with tubular A-Arms, coil overs moved from UCA to LCA, double adjustable shocks all around etc. The car turns like a go-kart. So much fun to drive!
My racing days are over, I really should sell that Longacre Caster/camber gauge, if any of your racing buddies needs one let me know and I will dig it out.
My Lexus definitely needs more caster, wish me luck trying to explain that to the "alignment" guy.
Have fun
ConnorBe,
Have fun
We tend to run ~ -4 degrees camber in the front, and -2.5 to -3 in the rear! In racing its really about optimizing the tire and adjusting to the preferences of the driver on the day, though sometimes those things contradict each other which is when it gets challenging.
Since it's front wheel drive, on some tracks we actually will put toe out on the rear to make the car rotate. Not advisable for a road car!
Our little Hondas are caster deficient too. For a front wheel drive race car it really needs to be about +10 - +12 degrees.
0.050” - 0.070” removed on 20 pieces, could be 200 pieces. Grinding would do a real nice job. I have a good sized 3 axis automatic grinder, and I’ve used it a fair amount - that is a lot of grinding!
It totally makes sense that your preference is to mill it, then harder to hold (so Dan’s suggestions - with small recessed screws would be important). In my experience it is possible to mag hold for milling - possible, but tricky, certainly not preferred.
Obviously trying to fixture and hold comes at a price. Using a not so big end mill would reduce the tool push, but increase the machining time. Everything is a trade off. Maybe a mag sine table on the SG and just let it buck (perhaps an hour per shim?)?
Regardless it feels like quite a bit of shop time, they are going to be some pricey shims!
The hassle factor is certainly the biggest issue! Last resort I may need to buy a mini mill and a cheap angle plate and give it a go myself. I was supposed to be saving for a nice lathe!!!!
I’d look at putting the angle in first on stock that can be held on an angle (face mill or fly cut) then a CNC mill can profile cut it out. A few small holding tabs as it’s getting profiled will keep the small features in place.
I might be interested in, but I’m not available to really look into it until mid June.
