Old Villiers engine.
terry_g
I inherited this engine from my grandfather. I haven't started it in a while but it runs great. There is a weight in the cam that operates the ignition points. When max RPM is reached the weight stops the points from closing shutting off the spark. It is a hit and miss engine.
The Carburettor uses spring loaded discs to create a vacuum not a venturi.
Tomc938
That is so cool! What's the approximate diameter of the flywheel? Nothing to gauge size with.
I wish someone made the casting available as a kit. Looks like it would be a great project
trlvn
The flywheel is 12" in diameter.
What was the engine originally used for? Is there any indication of horsepower?
Very cool. I've seen a few hit and miss engines come up for auction recently but nothing that looked like that!
terry_g
I have no idea what he used it for. He was a trapper in northern Manitoba.
It probably had a few uses.
I would guess the power output at less than one HP.
GVBoK
My Dad used to have a motorized-bicycle with a Villiers motor on it. Not sure if it was stock, a kit, or something he cobbled together.
