Tool Nothing Lasts Forever
Tool
ChazzC
It finally happened:
IIRC, I put a fresh Energizer Silver Oxide (China) in about 4 years ago – I'd forgotten what a PITA it is to get the battery cover off.
That looks a lot like my ‘90s vintage Mit, back in the day the buttons were like that.
D :cool:
Really odd. My older style Mitu eats a battery a day. Not really, but you get the idea.
My newer ones are works of art in every respect.
I have to check my Accusize (left hand 6”, easier to read OD’s on the lathe) to see how it’s doing, but all of my cheap ones (HF) are stored without batteries to avoid issues.
Odd. My Mit lasts forever on a battery.
D :cool:
The real issue is the state of the art in the old electronics. The first MIT's with a display were hungry beasts, but even that was manageable provided you turned them off. That was their Achilles heel. Too easy to forget they were on. Next time you used them they were dead.
I tried removing batteries for a while, but I still failed too often. I have a digital micrometer with the same problem. I put a flag on it to help me remember. I also bought a hundred batteries......
The new ones have auto off. But even so, they are also not battery hungry. In fact, I'm given to understand they don't really ever really get turned off. It's just the display that turns off. But the new electronics are very low draw and don't eat batteries.
@Susquatch
Forgot until just now to check the Accusize Left Hand caliper: either the battery evaporated or I took it out since I don't use it as much as I thought I would when I got it 4 years ago.
@Susquatch
Want a laugh on me? When you first mentioned it, I thought "is that like a left hand screw driver"? LOL!
But then I thought a little more and realized there might be the odd time that was useful. I don't think I'd go out of my way to buy one though. I suppose if I needed another caliper anyway, perhaps then. But it wouldn't be a high priority.
What’s so funny about that? I have a full set of left-hand screwdrivers I got from Dave @mmcmdl
Yeah, I forget where I saw one, but it made sense and found the Accusize at a good price. Since most of my parts are small I find myself using the Mit Combi-Mike most of the time; maybe I need to start looking for a 1 - 2” Combi?
Never owned or even saw a Mitutoyo Combimike. I have heard them mentioned every 10 years or so. I can't really see a need for one of those either. But there is always some one who needs something a bit different!
I like mechanical digital micrometers: never have to replace the batteries!
I didn’t know CombiMike’s existed until I found one in the QA metrology no no one wanted at the Raymark Friction auction in the late 90’s. I like them because I don’t need to think (or use a calculator) and they fit my design style: many of my designs have mixed measurements, using inches for stock and millimeters for holes, locations & hardware.
I picked one (0-1"/0-25.4mm Mech Combi-Mike) up in a Pawn Shop for $15, a LOT of years ago! Tenths reading on the Thimble in Inches, and hundredths reading on the digital readout in Metric. Still have it, too! Made a simple stand for it so I could hold a part with one hand, while still being able to operate the thimble with my other.
My Mit Digital caliper is newer than yours, so not as power hungry. I recall the Starrett Digital Calipers were hell on batteries too, at the start. You either bough batteries in bulk, or learned to remove them without fail....
I bought that set when I tore my right rotator cup . Found I couldn't do ANYTHING left handed . ;)
Hey, you joke, but I had a whole selection of Right and Left handed driver bits!
Dealing with aircraft screws that had been mangled by too many worn or mis-applied tools, there was an outfit that offered what they called ACR, or Anti Cam Resistant, IIRC, driver bits. They had extra teeth built into their drive faces, so that they dug in to the mangled screw hole, rather than slipping up the slippery (worn) slope and out. You could order a #2 Philips bit with teeth facing for removal, facing for installation, or with teeth facing on both surfaces! We leaned heavy on the Removal side! :)
