It's a cncrouterparts.com partial kit. I purchased all the steel parts from them and sourced my extrusion/CRS in Canada from a company called Faztech in Quebec. Currently using Mach3, but I have Mach4 Industrial which I will switch to at some point. I was a early bird purchaser of Mach4, so I got a free Industrial license when it came available. I use Ger21's screenset for Mach3 and I really like it. It's one of the reasons I haven't switched over to Mach4 yet. The other is the lack of a driver for the XHC HB04 wireless MPG I use. That issue is now a non-issue since I wrote a plugin for it.
My control system itself is a Smoothstepper attached to a cnc4pc C32 board. I also have an additional C10 board connected to the Smoothstepper. G320x servo drivers from Geckodrive and 1100oz/in servo's on xyza. My spindle is a chinese watercooled 2.2kw with VFD from ebay which uses ER20 collets. Guess what collets I use on my King KC20VS milling machine?
I printed a hovercraft using my delta printer. I had to split the frame in two pieces. I will be able to print the whole frame as one piece. I've also tried some other things that I could not print as one piece. Of course it took something like 34 hours for each half of that hovercraft. So that will be interesting
