need infos for increase a hole from 3/4 to one inch this blade is from Stihl blade the number is T15 07 4000 713 3902 MAX 11500 RPM
Marc Moreau
Marc Moreau
This blade is designed to cut small tree branchches . Its thickness is 4 mm . I tried with my press drill at low rpm with all lubrican I had but I always damage my bit without success . I cannot mount it on my metal lathe. I need your experience. Thank You
I have done carbide circular saw blade arbor holes on my mill. I use a boring head with a boring bar. Usually a couple passes to go from 1” to 30 mm. Run the mill fairly slow with a slow feed rate. Cuts very easily.. I usually clamp down and indicate the hole and then change to my boring head to bore the hole.
You would probably have a lot of chatter on a drill press using a drill.
Martin
wonder what they make those out of? Must be tough stuff as the body is the same material as the cutting edge. what did you use for a drill, twist drill or step drill?
Even if it was mild steel, that would be hard to do on a drill press.
The way to do it is like Martin says, using a boring head in the mill. If its tough material light cuts with a carbide tool should work. I do this for my table saw - every blade starts at 5/8 but I need 20mm.
Do you have a mill? Cheapo boring heads aren't outrageous and work well enough. I thought about making a cutter like a counterbore with a pilot, but if its tough material that won't work well and it is an very big cut to do in one go. It needs boring in a bunch of little cuts me thinks.
Last ditched idea - file or if too tough, die grind. Incredibly accurate work, to a thou, can be done with filing but it takes lots of patience. Turn a test piece with a taper that you put blue on and keep measuring to keep it centered.
I don't know how big this blade is, but I have had success screwing blades to a piece of mdf (or plywood) and holding in the four jaw. Adjusting the 4jaw until the existing hole runs on centre then just a boring job.
Gary
