Tool Need a good source for a Dovetail Cutter
Tool
LenVW
Process Machinery Designer
Looking for a . . . 2” Dia x 45 deg. I have 1/2” and 5/8” R8 collets, As well as 10 and 16mm sizes.
I have went looked thru the Chinese Products on Aliexpress & Amazon, but, they tend to leave the shank dimensions out of the description.
Any experiences or recommendations to share ?
Isn't this the shank diameter?
*** oops sorry, replying to wrong person... I think thats what you are saying as well ***
LenVW
The smaller overall diameter cutters seem to have a ‘reduced’ shank diameter just above the cutting faces. Looks to be a weak area of the shank, especially for dovetail cutters.
I was hoping to stick with a minimum 16mm shank, straight to the cutter faces.
Can I ask why 2" diameter? Usually the bulk of material is milled out conventionally with a straight EM & only the remaining angled sides are milled as a secondary operation with smaller cutters. That's easier on the dovetail cutter loading & those cutters can also do narrower dovetail slots. I think the neck-down (relief) is to get a clean cutting edge for the entire angled surface & accommodate narrower dovetails?
I've seen big diameter dovetail cutters but usually with carbide inserts (big $$).
Make your own indexable holder. and show us pictures. I made something similar... but 45 chamfer.
Did you show us this John?
hmm not sure. The slot for the triangle has straight sides. Ideally I think they should match the slope of the insert. Works fine though. I ordered one of these from MZG and then got impatient. So now I have a factory one and my verision..
Arbutus
I agree with PeterT. The narrow shank is needed to achieve the correct clearances. But also the length of the neck is important. The Aliexpress cutter shown above has a short neck which means the depth of the upper corner of the dovetail slot is limited, and would be quite close to the top surface. A longer neck allows the dovetail to be cut deeper in the material.
This cutter from Toolmex works very well in cast iron and 1018, cost about $45. Larger ones get exponentially more expensive. An indexable cutter is also very good option.
you can see my version has straight surfaces to hold the index but the commercial one has angled sides, and also it has a sloping bed to reduce the cutting angle. Looking at mine more closely I see there is a small gap between the side of the index and the holder. I made this four years ago - I hope I can do better now.
LenVW
I know the reduced shank diameter is for clearance, but, a lot of these Chinese products seem to reduce it to the point of weakening the tool.
@Janger . . . I like your straight shank. no stress concentration with it.
I may attempt that pocket machining in CR Bar.
Note:
The last carbide insert ‘pocket’ I machined was about 35 years ago on an Ex-Cell-O 602 mill.
