Narex VHU 3 1/8" Boring Head Mods
I received the accessories. Arrived with the plastic insert damaged, but the case and tools are all good. I have to clean them all up, and make a handle with a ball knob on the end, and we're all done. Unfortunately, it didn't have the lid for the case. Maybe I'll make it one day. Oak, leather covered, felt lined😎
Nice work. I notice you mentioned the runout during machining. Have you mounted the boring head in the mill with a solid boring bar. Toss an indicator on it on 90 degree angles both vertically and horizontally. Should show any indication of runout in your mounting/arbor.
Theoretically it shouldn't matter for vertical boring, but might make a difference for facing or cutting o-ring grooves etc in horizontal positions, especially at bigger diameters.
Thank you!
I haven't checked it yet, but in post #14 of this thread, you'll note that I surface ground the boss where the arbour attaches to. I'll have more of an issue when facing with the tram of the head of the milling machine being off.
Thank you!
I bought a used Chandler boring head, similar to narex and does facing. I had to change the arbor to R8 and machined a new one in one process to ensure it was true and concentric. Installed it and found the head was off. Arbor checked out perfect, it was within the build tolerances of the boring head. Negligible for my usage and not a problem for vertical boring, but if I need to do some larger diameter facing, cut a large diameter o-ring or similar project, it's something I need to keep in mind. I tried attaching pics but it wouldn't let me.
