I came across a Kijiji ad for a "Myford ML7 Lathe for Parts" on Monday about an hour after the seller posted it. Looking through the pictures all of the major parts seemed to be there and it came with a whole bunch of other random stuff (some was related to the Myford but plenty was not). The guy wanted $300 CAD for all of it and he was only 30 mins away from me. It felt like stars were aligning to tell me that I need a second lathe in my life.
By noon yesterday the seller had gotten back to me and confirmed that it was mine and after work I went with my brother to pick it up and we continued my
habit of bringing lathes home in the trunk of a silver sedan.
While I could see a lot in the ad's pictures, It wasn't until I got home that I was able to take a decent inventory of all that I bought. On top of the mostly complete ML7, I got a 3 jaw chuck for the Myford, a 1/3 motor with pulley, a couple dead centers and a cheap live center, a bunch of assorted HSS blanks (quite a few of them are ~3/4", which I'm not sure what to do with), a bunch of misc. metal stock (mostly steal of unknown type), a decent looking little keyless jacob's chuck with a MT2 arbor, and what I'm 90% sure is a second but much cruder lathe. On this second "lathe" there was a 6" 4 jaw chuck with a 1 1/2 - 8 tpi thread that fits my Atlas lathe, which was a nice surprise! There are also a bunch of random gears that seem to have nothing to do with the ML7.
A bit of a tangent, but the crude little lathe is marked on several of its parts exp27. I think I can very faintly make out a "CMA" marking on one of the castings, but that is literally all that I know about this thing. If anybody knows anything about it I would be interested to know more. Looking over the pictures from the ad now, I think there was another section of dovetail plate and another dovetail slide (cross slide maybe? or possibly an incomplete tool rest for wood turning?) for the crude lathe that I didn't actually end up getting with everything else, but I'm really not very concerned about it.
As for the ML7, here is what I know is missing.
- The gear on the back of the spindle to drive the change gears
- Probably several change gears (I have maybe 5 or 6)
- A bunch of random screws and fasteners
- The cross slide gib
- Belt covers (I can live without these or fabricate something if not)
- Change Gear cover (I would like to either find one of these or fabricate on if I decide to keep this lathe long term)
- Several oilers
- Spindle bearing oil cups
- Quite a few gib screws
- Bull gear (present, but missing one tooth)
In addition to the missing bits, just about every single part of this lathe has very obviously been taken apart and messed with. I haven't found a single nut, bolt, or screw on the whole machine that is actually tight. I'm also pretty sure that there are a couple of pins in the spindle missing. A major part of this project is going to be taking the whole lathe apart and putting it back together again.
I did a cursory inspection last night and so far I've concluded.
- The spindle doesn't have any noticeable play side to side, although there is probably 0.005" of end play, but I'm pretty sure that's adjustable and can be attributed to nothing being tightened down properly.
- The bed looks pretty decent and there aren't too many nicks and no big gouges in it or any obvious signs of wear. I'll have to look closer to confirm this.
- The cross slide is in a bit rough shape. It's pretty dinged up and there are two spots where the T-Slots, which tighten the compound slide have had broken out. The one part that I think is mechanically fine is the tailstock.
- The countershaft assembly seems completely fine except for a missing oiler
This should be a fun project for the summer and hopefully I can get it into some sort of decent mechanical condition in time for winter. Then I'll be able to play with a lathe inside instead of freezing in my unheated garage in -20° C.
