Myford Lathe OBO
MashingMetal
When there was no price, I asked and there is no gear set or anything else, so I offered accordingly and pointed that out. I guess it wasn’t what they think it worth. Lol
$1500, Caledon ON
You are better off with the lathe in Sarnia. At least it has attachments (both steadies) etc.
I agree, it ends up costing way more in the long run not having accessories. Just kicking tires at the moment, see what comes along save up some money in the meantime.
If you are a "I must have a Myford!" person, there are at least three in the Vancouver area and here on the Island listed on FaceBook Marketplace. I know nothing about any of them, other than that they have been listed for a while. I'm sure one of the forum members nearby would be happy to keep it warm for you until you can come out and pick it up... :D
Thanks, I am in Ontario, so easy pickings around here for Myfords. Since getting a big lathe, I kinda wish I had a smaller one again as a second machine. I am sure something will come along.
Hold out for a Super 7, instead of an ML-7. Quite stiffer and more solid headstock spindle. I have had both. At the same time. Still have the Super 7! Both have the same 5/8" spindle bore (not that big a deal, given the size of the lathe) but the Super 7 has a far larger diameter spindle through the headstock bearings. If you push it, it really shows, based upon my side by side comparisons.
Gearbox for thread-cutting would be an obvious bonus too.
Familiarize yourself with the differences between the older models, and the newer ones. You might just get lucky and see a newer power cross feed unit priced like it was an older one... Luck favors the prepared!
Be prepared to pay to get a machine that is well accessorized! Buying the extra bits later can run some money. But, on that same note, try not to overpay for accessories that you do not see uses for.... Again, luck favors the prepared!
As a minor aside, if indexing seems in your future, the Super 7 uses a 60 tooth bull gear (dead nuts common, in the dividing head world, as it covers so many options) while the ML-7 uses a 65 tooth bull gear, which does limit the divisions somewhat... George H. Thomas covers that in his Workshop Practices books (which I will recommend to EVERYONE! :)
Thank-you so much for taking the time to write your comments on what to look for. Sounds like there are some good features that are worth looking out for.
Thanks again, Mark
Thanks again, Mark
A few thoughts for you Mark.
There are a few Myford guys in your area. @CWret and @trlvn come to mind. I'm not sure about @trlvn, but I know Craig @CWret has a Super7. I also know that Craig would be able to tell you who else has one and might also be able to tell you what to look for. I'd recommend you connect with him.
Lastly, you might want to plan to attend the April Meetup in Aylmer.
2025 SW Ontario Meetup
I think I replied with a “maybe” to attend the meetup, see what happens as we get closer with the family.
I am not in a hurry for another lathe in the shop but just keeping an eye out and what to look for.
Thanks, Mark
Thanks again, Mark
Welcome.
I started my hobby machining journey before we had very much Internet to look for info on. Lots of magazines and books though! On the Myford front, that really means getting in to some of the British sources for information, as they inevitably assume you have a Myford, making it really reassuring if you are in any way nervous.
Again, I will give a STELLAR shout out to the George H Thomas Workshop Practices Books, available from Hemingway Kits if not Amazon, etc. https://www.hemingwaykits.com/the-apprentices-library
The 'Gold' in a used Myford, is getting a late model with the power cross feed. They have a different looking Apron, with the extra button to engage the feed. Check out the www.lathes.co.uk site for more info.I kinda disregard the later 'Modern' Myfords, (Big Bore Super 7) as they really represented a stupidity level of spending for value received. Last gasps at trying to stay in any way relevant. I wouldn't pass on one if it was priced at regular Myford prices, but, at the end of their run, they were trying to get better than $22K Canadian, for a Super 7 without much more than the most basic equipment, and, as much as I like my Myford, if I was spending that kind of money, well, the world is my oyster, so to speak! I'd own Schaublin or Hardinge for that kind of money!
Condition is King! Unless the lathe has had a paint-rebuild, you can generally get a pretty good sense of it's overall condition by the way it presents when you look it over. Nice, if it is clean and tidy, but if the paint looks great under a layer of grime, you might pay yourself very well in savings, for doing the cleaning that he prior owner didn't... My lathes never looked that great, but they were slathered in oil, and despite their sketchy looks, they were in pretty decent shape under the grime. Yeah, I'm 'THAT' guy, not an absolute fanatic about polished and clean. But my machines are ready to make decent parts...
It is not too hard to see where the carriage bears on the bed, vs. where it does not. A close look at the wear that will be there, is worthwhile. It's not going to be very much, unless the lathe was beaten upon as an industrial tool, but it provides a quick reference to visually see the wear that may be present.
Chucks. 'Gold', is getting a Burnerd Adjust-Tru 3 jaw, but don't be afraid to take what is on offer. Burnerd effectively priced themselves to a point that even Myford stopped buying them. Which is kinda ironic, given that Myford did the same to their machines... But they are out there. The Burnerd 4 jaw integral (threaded directly, rather than a chuck bolted to a threaded backplate) chuck that was stocked is pretty nice too, and doesn't eat your between centers distance. I think, near end of run, Myford had switched to some eastern European sourced chucks (Bison?) which were still, really good tools.
I made a (butcher's) clone of a Tripan 111 size tool post for my Myford, a bunch of years ago, using my Super 7 and a milling slide, and think it is pretty much the right size and volume to match the Myford's capacities. I have about half an ice cream bucket worth of tool holder blanks that I made, so it suits my needs well. A decent quick change tool post is a life changer, IMO.
I like my Myford, figure I will die with it in my basement, unless i stumble upon a decently tooled up Schaublin 135 or 150, at which point, I upgrade a LOT! LOL! But the odds... Even more laughable! Myfords are not the be-all-to-end-all, but they filled a gap between the then current industrial production, and the truly dismal crap that was foisted off on the hobbyists before China started making truly cheap and nasty machine tools... And they are a pretty decently built, decent quality product worth investing in.
@trevj Thank-you so much for your thoughts. I am a bit of a British machinery nut, shaper, horizontal mill and large lathe, grinders. So I was looking at the Myfords for small work. I will read up and see what comes along. I have read quite a few model Engineering books and you are right, all centred around the Myford. It would be nice to get one with a quick change, but not essential.
Thanks again, Mark
Meetups are a great way to meet and make new friends. I hope you will be able to attend (April 26 in Alymer)
As Susq said above "There are a few Myford guys in your area" I have a Super7 - we are almost neighbours, so come have a look and kick the tires.
Thanks again, Mark
Oh yeah, forgot to mention, aside from the heavier duty spindle, on the Super 7, the max RPMs is considerably higher too, 2500 RPM, vs the topped out ML7 at around 1400.
While a minor point, the extra revs are pretty handy, when making small diameter parts, and with our ready access to sintered carbide insert tooling, many larger diameter works can be done at speed.
As a companion to my Super 7, I also have a Centec 2A mill with the optional Vertical head. It uses MT-2 taper in both spindles, so it makes for some commonality in the tooling between them.
I worked part time in a Brit Bike shop, too, and had a series of Norton and Triumph bikes, and bike projects. Yeah, I get the draw! :)
I have a pretty extensive collection of Model Engineer magazine, not even nearly complete, but the early issues dating back to before 1900. What I found most interesting, was seeing the truly grim little machine tools that were the 'standard' for Amateur use, Myford really raised the bar a LOT when they started producing the 7 series lathes after the war. You get a really good picture of just how tight the Brit economy was (pretty much based on the model of "Export or Die!") in the post Second war years, reading through the articles at that time, though most were really careful to dance around the subject and only refer to it obliquely. But the main point I make, is that the average metal lathe, targeted at home shop guys, was a nasty little thing that would have made learning to make decent parts that much more difficult. I cannot imagine the sheer joy that a Brit Model Engineer would have felt, had someone dropped the cheapest and nastiest version of a Chicom 7x10 lathe in their lap, back then! LOL! We really do have things SO good!
We, collectively, in Canada, had it pretty good through that period, in that we had the disposable income to spend, and had the access to a great qty of those Exported goods, making for a pretty solid amount of these small British machine tools making it to our Commonwealth shores.
@trevj Thanks again, you make a good argument for a Super 7. The Triumph I have really doesn’t go fast enough for carbide/small parts so the reason for looking at another lathe. I need to first reorganize my shop this summer and move the machines around.
I know about the British Bug, we have MGs and Triumphs in the garage and Wadkin machines in the woodshop.
