grease monkey
just another day!
so I did a thing, and its morphed into 2 things, on the hunt for a new daily driver trailer puller, and wanted something unique, I bought a 1968 Mercury M100 1/3t truck, mainly for the body and badging to swap onto a 1979 F250 4x4 frame that will be getting a 24v Cummins 5.9l engine swap, but after some google university, I find out that Ford cancelled the Mercury truck program in April of 1968, and the quick search also showed this Merc as being built in April, so this very well could be one of the last survivors of only 334 trucks built in '68 model year, the rest of the trucks they built were 3/4t and 1t trucks... I have a cab and box for the 1979 build that are from a 1970 F250, so its going to be the correct era of truck, on what I consider the best frame to have from back then, a 1979 F250 4x4 that currently has the same vintage dana 60 1 ton axles front and back, this truck also wants to be a Mercury just for choice, but find the badging is proving difficult. 1st pic is the Merc in its current running and driving state, needing some floor and door rust repair to make it road worthy again, second pic is my preferred build in its current state, the F250 is slated to receive a 1999 Cummins 24v engine thats been converted to full mechanical (because I'm so done with computers and want fuel mileage, not hp) which has a NV4500 5 spd manual trans bolted to it with a new clutch, and a NP4100 T case behind that to do the 4x4 duties. going to try my hand at using an adapter to siphon dry baking soda through my pressure washer wand to remove the primer paint and reveal the original pant on both trucks, reading good reviews about that process. also just finished a project with my son in rebuilding a rare John Deere 332 factory diesel awn tractor, which is for sale now, (if anyone is looking??) and currently have the engine out of a 2009 Mini Cooper, to hopefully be rebuilt. also had the opportunity to machine an adapter pto shaft to bolt o the crank output of a Kubota D482 2 cyl diesel to go into a John Deere 317 tractor Dad is working on, turned out very well! my machining center is becoming more and more useful, so thats good news in my books!
