terry_g
Yesterday I went to use my old Walker Turner 16" bandsaw. I flipped the power switch and the motor started to pick up speed but it seemed slower than usual and did not get up to full RPM so I shut it off. I opened the covers and turned the wheels by hand and they were free. So I flipped the power switch on again and it started up but was gaining speed slower this time and then it tripped the 15 Amp breaker in the panel. The 14 gauge three wire cable going from the switch to the motor was warm to the touch.
The motor is a 110/220 1.5 HP 3450 RPM Wagner Leland motor wired for 110 volts. I took the cover off the starting capacitor and un soldered it and tested it. The capacitor was a Mallory made in Canada and 540 mfd. My tester said 542 mfd. So I reinstalled it. I took the cover off where the power wire goes in and made sure all the connections were tight and they were, so I took the belt off and turned the power on again. Motor ran up to speed right away, I let it run for a couple minutes with no problem. I shut it off and put the belt back on and turned the power on again, It spun up to speed like it normally does. I made a few cuts with it and it seemed to have the power it always had. Shut it off and restarted it several times without a problem.
What is going on? The starter switch not disengaging should not trip the breaker that quickly should it. I don't trust it now.
