lucsimoneau
Hi all, hope you are all doing well.
I'm presently using the following mist coolant setup obtained from AliExpress for a few bucks:
The problem I'm having is that my compressor (Maximum 15-Gallon Oil-Free Portable Vertical Compressor) runs almost continuously to keep the aire flow and mist going.
I've been reading about a Fog Buster system and it seems to require les air from the compressor. The company states that a 5 gallon compressor is sufficient.
Do any of you have some experience with the Fog Buster system and the feasability to do a DIY solution?
Thanks!
Thanks!
