Ok let's try again.
Hey I have the same lathe. I moved it and did take the head stock off. I cleaned super well (no abrasives) with degreasers and rags. Now I question the alignment of the headstock. Any suggestions to check/ realign?
My motor is on the back side. I have a 240 single phase running it.Check with Craig he successfully removed his headstock. I left mine attached. I am just getting ready to run my lathe again after the move. It is all together. I have the cheapest vfd off amazon to run it so we will see how well that works. Mine has a 3phase motor on it. Is your motor in your base or on the back side?
Just bolt it back together (you have already cleaned it well - that is the important part). The alignment was established when the machine was manufactured. Check by doing test cuts (~1” diameter bar, extended 6” from chuck, no tailstock support, cut ring about 1/2 wide at the outer end and near the chuck, with the mid-region under cut, very light cuts with a super keen tool) - then measure the resulting diameter.Hey I have the same lathe. I moved it and did take the head stock off. I cleaned super well (no abrasives) with degreasers and rags. Now I question the alignment of the headstock. Any suggestions to check/ realign?
Do you work for, or own, Solid Hook?this is not a DIY job for most people. If you were in Ontario I'd say call Solid Hook, they do machinery moving with proper skates and Versa-Lifts. For Alberta, find a local rigger who's done lathes before. The stair descent is where most accidents happen
