Sorry, no pictures today, but I moved the Modern 9X49 to my storage unit, solo, with a u-haul 6X12 with ramp and U-haul pickup truck.
The mill had been moved to a quansa hut in the front yard of the seller's place, and the ground was super soft, so I had to limit trailer corrections to keep from chewing it up. It had beed stored well, with oil-soaked cloth on all surfaces, and a weather tight cover over it.
The head & ram was removed- 400lbs I suppose, and on a pallet. Used my 2-ton engine hoist to lift it, backed the trailer under it, built a wheeled cradle from moving dollies($19 Princess Auto), and some 2x4 lumber. Pushed that to the front of the trailer. Easy. Head sits upright, very easy to move around and pick up, by slinging forward of the motor, then using a ratchet strap from the hoist to the rams eye bolt to level it.
The base, with bed & knee was challenging. It was on 2x6's, which had sunk into the soft grass at varying levels. Lifted with the hoist at the 1.5T length, after laying down some scrap ply. Backed the ramp under it, braced the ramp, lowered it on to some more ply, then used two 2T come-alongs and some slings to drag it forward. Done. Amazing arm workout, but I sweat like a pig.
That was about two hours of solid work. Plus two hours of driving.
At the storage unit, I screwed a d-ring into the concrete(SHHHHH!!) at the back of the unit, then backet the trailer right ip to it's 6" lip. Dropped the gate and used the engine hoist as a dolly, this time lifting it just so it cleared at the 2Ton arm setting, and pulled it off with the come-alongs. Hoist wheels dug into the ply and needed some pursuading and steering on the ramp, but it went smoothly, and the hoist 's six wheeled configuration made the 1.5" transition off the ramp with no issues.
I jacked the tongue of the trailer up to induce some incline, and the head and ram rolled right off in a minute, without any rigging needed
I used, from my tool kit:
1-Engine hoist.
12 ratchet straps
2- 2T come-along hand winches
2-48" 3ton slings
4 24"X 1" climbing webbing slings(3600lb rated).
2X 24"x 72" pieces of ply.
2X 48X48" pieces of ply for uneven ground and protecting the trailer gate's steel mesh.
2X 2x4 cut for cribbing and trailer leveling, pry bar wedges.
1x 4x4x48" post section for leveling.
1-3/8 16 eyebolt
Hammer drill.
Uhaul was about $150, gas was $30 for a 170km round trip.
I'll post some pics when I start cleaning it up, but it's in great shape, like a showroom condition demo unit with a little storage dirt on it. Bed has some surface rust, ram ways have some surface rust, but there's lube everywhere else.
Thank you CMHW and members for posting this listing up, I was able to get an amazing mill for nothing, aside for a days hard work. Looking forward to sharing it's rehab and assembly.
P
****Edit:
Next time I have to move it, I'll be building a low profile carriage out of angle iron, with 6 1000lb casters. I think this is a good tool to have around the shop, but I haven't seen a good design that allows them to be mounted to a mill, then jacked up. I'm thinking butterfly bolts that could be inserted into the base, then spun up with an impact driver, might do the trick. I'd also consider making a decent portable electric winch that can run off some dewalt packs or similar, with at least a 5 ton capacity.
It's getting hard to find reliable machinery moving companies, I got quoted $2600 for this move.
