Mini Shop Vac
I find I use my mini shop vac quite a bit around metalworking. Not big chips obviously but just sucking up swarf off the machine or work & general house/shop duties. Suction wise its pretty good, but the canister & size doesn't really lend itself to metal like it did with woodworking & general clean up. I am cheap so I empty the bag several times & re-install.
https://www.homedepot.ca/en/home/p....le-wetdry-vacuum-with-storage.1000527616.html
I got looking at these kind of more upright cans & from what I can tell, no bag at all. Just the motor intake filter inside.
https://www.amazon.ca/Dura-Vac-EATC...47062725&sr=8-1-spons&keywords=Dura+Vac&psc=1
https://www.homedepot.ca/en/home/p....tachable-blower-and-dust-bags.1001115422.html
They always show them sucking up messy, fine particulate like fireplace ash or BBQ pits. Are these new technology or still like older gen shop vacs I've had where yes, 80% of fine stuff like drywall dust stays in the pail but 20% bypasses & gets pumped out the exhaust & re-distributed over everything you own? Being bag-less, the metal chips might not have this issue but would it impale the filter & then I'm buying new ones of those all the time? Any recs or comments welcome. I don't really want to build a cyclone although I see the logic in them.
I bought the biggest rigid shop vac home depot sold because they said it was the quietest model. I buy generic bags from amazon and they do ok. supplies from HD for it are stupid expensive. I can't empty the bag as it just busts. I usually pick up most swarf with a homemade magnet pickup sweeper.
#3
While a lot of my equipment may suck, my vacuum is one piece of equipment that does and I'm glad!
I use a wet/dry Craftsman shop vac. It's big and cumbersome but has an air cleaner style filter and the canister is the bag....although I think you can get disposable bags for it. I use a fine filter bag (made for drywall dust) between the disposable air filter and the canister itself. I just about never replace the inner filter and only occasionally shake off/hose off the fine "filter" cloth bag, that catches it all. It has good suction and big hoses/inlets. I suck up all sorts of oily swarf with it all the time. Occasionally I will get a jam when sucking up big long swarf. It's also very loud.
Ended up getting this one
https://www.homedepot.ca/en/home/p.nxt-45-l-12-gal-50-peak-hp-wet-dry-vacuum.1001157716.html
Suction & noise seem good. I find the big diameter hose a bit clunky. Of course they sell a smaller more flexible one as an add-on. I wonder how that paper filter will hold up to metal swarf. I know with wood dust & regular duty crap I would just brush along the creases & clean it off. But the swarf may impale the paper. Guess I'll find out.
That’s similar to the one I bought. I did get the car kit with the long hose. I use it frequently and appreciate it not as loud as some of the vacuums out there. My neighbor has a real screamer a few doors down. I can hear it inside my house when he’s running it in his garage.
Knockoff bags on amazon are ok. I clean the filter with compressed air. I haven’t had to replace it so far. I ran it without bags but it just blows so much more dirt out the back the bags help with that.
#6
That essentially is similar to my craftsman. If a cloth bag is not available you may want to make your self one. On my vacuum when I use the extra cloth bag I attach the suction hose down on the drain outlet. The extra cloth bag does cut down on suction force but it really doesn't matter much as I still seem to be able to suck up shop rags, notes, 22 shells, loose new carbide inserts and the like.
Bofobo
the last bit here sounds horrible
#9
The open canister sounds like the ticket. Lost an allen key to my ShopVac today LOL. When I opened the vac up to see If I could recover the key I discovered the bag was full to the nuts and weighed in at 6 lbs. Was way over due for a bag change but still sucking up all manner of stuff.
