Milling machine-mechanic’s special
Frcsc6el8
Active Member
Located in Cobble Hill BC
Nice small machine for home workshop. No motor, no vise, no handles no tooling.
NMTB30 in horizontal spindle
Couldn’t tell about vertical spindle
Very solid apparently came from a local high school
Floor model but would need to go on a plinth for a comfortable working height
No affiliation with seller:
Syd Haskell 250-886-2658
Tomc938
Too bad these get left out in the rain.
What kind of HP do you guys think this should have? (Dang, I'm a sucker for a fixer upper)
Also: thoughts on reasonable price?
YotaBota
Mike
Cheap, real damn cheap, scrap price would being generous.
If you tell him you're coming from up island a case of beer might do it but a couple of hundred bucks should get it.
IIRC that machine has a motor for the horizontal and another for the vertical, candidate for 3ph and a vfd.
It would make an interesting project, parts may not be hard to get as most of the Chinese mills are clones of something decent.
Tomc938
Any guess what a used 3 ph motor would cost? Best guess would at least give me an idea.
I got a 2hp 3ph in Calgary for $60.
I just bought two brand new takeoffs for another member - one 5hp and one 2hp for $50 each on Kijiji.
They sit for months at 2 or 3 hundred and then the seller puts them at the curb or takes your fifty dollar bill. Forget about the scabs and resellers.
Look for typos and mis-categorized stuff and look how long it's been listed.
Your biggest problem won't be price. It will be frame and shaft.
YotaBota
Mike
VFD cost would depend on your preference for quality and functionality, $100 or less from Amazon/Ebay to $400ish for a Teco.
The handles are missing but at least the dials are still there.
@Tomc938 - Have you wandered around the local machine shops and manufacturing outfits? One of them could have a machine sitting in the corner that has be replaced or just isn't used enough that they have been "thinking" about getting out of the shop.
Tomc938
Thanks for all the input guys!
I'm gogn to see if I can get ahold of the seller today.
And @YotaBota, great idea on the poking around machine shops. there aren't many here in Campbell River, but Nanaimo North the options open up a bit more.
After looking carefully at it, perhaps a touch more.
I assume he can load it on a trailer for you...
This is definitely a project machine. Perhaps 100 hours of rebuild. Spindle bearings will be usable for a short time, but will need replacing - it has seen a bunch of rain and it's a good bet that you head has water in it. I wish I could see the RH side of the machine, where the hand wheel goes.
It is all there, and a good machine can be made out of it. Check for backlash in X and Y Z should be undamaged from moisture. If X or Y won't turn, or there is more than .100 backlash in either, 300$ tops. Making new nuts/replacing lead screws startes to rapidly erode the value.
DavidR8
Scrap maker
I stumbled upon an XLO at a good price, so if things work out with that one I'll pass on the project. The little things can quickly raise the value beyond what it's worth in the end.
It drives my wife nuts sometimes, but I do have a habit of seeing something like this and saying, "I think I can fix that."
Nice! I've read that XLOs are very nice machines.
