Milling machine, $3000, Sundre, AB
Sure ya can!
Exactly...... We have two of almost everything for a reason. ie. Two eyes, two ears, two hands, and most importantly a pair of balls, therefore it only makes sense to have two mills....... In fact since you would only be one away becoming a collector, and collecting can be considered to be something of a noble pastime. Think stamps, artwork, etc..... I am sure milling machines should qualify......
Hope that helps. ;) :p
At this point the only thing that holds a guy back is the size of said balls. :D:eek:;)
I saw a truck at the mall with about 5 or 6 of those balls things hanging off his truck, I don’t know if he was compensating or advertising.
A bit of a wierd voltage though. 440 would run okay on 480, but it’s already running on 60hz versus 50, so would likely run like a scared cat.
480 is the new 440. 60hz. They cranked up the power line voltage over the years.
That’s why there’s always the confusion of 440/460/480…. Or 100/110/120…. Or 220/230/240….. or 110/200v 3ph.. which now is 120/208…. or 575/600.
If it was 50hz the standard for that is 230/400v 3ph which used to be 220/380v 3ph…. Or 690v 3ph.
