I believe there may be a manual for this in one of the threads here.
Well, thank you very much. I will set to these reads. Another hobby of mine is readingHere's what I have to add, YMMV.
Forget about, for the time being, all the concerns about losing zero with height changes. For a long while, you will be doing most of your work by eyeball and cutting to scribed lines anyways, and, with a little practice, cutting to within a thou on a well scribed line (ie: one done lightly, with a SHARP scriber), is pretty easy to achieve.
Get a edge finder set with a wiggler, get some plasticene, and a few sewing pins, and a decent hand magnifying glass, and you can rapidly align your tool over any edge or scribed mark or dot.
The plasticene is used with a pin, to create an impromptu wiggler by sticking the pin to the end of the drill or mill, you true it up while it is turning (use a pen or popsicle style stick), and once it is running true, it gives you the center of the axis of rotation of the spindle. Align the point to whatever reference, stop the rotation, remove the pin and plasticene for reuse later, and carry on with your cut.
I can't emphasize how much a decent quality hand glass can change how much better you will see things. Once I started using one, it became a constant thing in hand, when inspecting tool edges, setting zeros on a CNC mill, and many other such jobs that can be done ok with the naked eye, but so much better with a better view of the situation!
Between magnification, and a Wiggler and 'Sticky Pin' for setting alignment, you will rapidly learn that it is not a big deal to find a reference point and set yourself up after any height change.
For a long winded collection of many different related mods and or improvements to the Mill Drill, take a look through the books published by Home Shop Machinist Magazine, one of their collection has most of what was a long running series of "Mill-Drill Adventures" where the author went over many useful mods improvements and projects, all related to improving the useability and usefulness of these machines. If you don't have access to a back library of the magazines, these are great books!
Direct link https://secure.villagepress.com/store/items/detail/item/820
Congrats on the new mill. Have fun!
Value wise, I think ya done good! Usefulness wise, the sky is the limit! If not further!
Height gages for layout are and were a thing, eh?Hmmmmm...... Not me. Not 50 years ago, not now at 77, and not likely when I grow up either.
Heck, I can't even scribe a line within a thou let alone cut that close using that method.
Magnification helps, as does setting up your work so it is able to be checked easily for dimensions, without removing it from the work holding. Between an accurate line, and a careful cut, it's not that hard to hit +/-.001".
Another work alignment tip! Centering over a hole. Use a dial test indicator (we had Starrett Last Word units in all our tool boxes, but anything you can mount in a common collet or in a drill chuck will work), and keep in mind that it does not matter what the actual reading is, just that you eventually stop the needle from moving!
Can't help you with the depth perception.Nice tip. I typically use a pin. If I don't have one, I make one. (always wanted a cylindrical grinder - and still do!) The only difficulty with your method is getting the indicator tip into the hole. I'm more or less blind in one eye so things like that requiring depth perception are a challenge.
I don't have a last word, but always wanted one. It has some nice features that other dial test indicators don't have. Just not willing to buy new because I have other dial test indicators that work well including both Interapid and Mitutoyo 10ths units. Might as well bury me the same day either stops working.
The same technique works in a hole as on the outside of a pin. the only difference is the way the contact tip presses.
How is that any different than sweeping a hole then? What am I missing about what you are describing?The main difference between a pin and a hole is that I don't have to be on axis with a pin. Just swipe past and note the highs. As long as it touches, it works. Easy Peasy for a one eyed snow man.
