TorontoBuilder
the size of the error depends on the distances between the reticle, the object being viewed and the viewer and the shift away the viewer is from the perpendicular.
In perfectly aligned scope in the bore of the mill there should be no theoretical error because the point being viewed is inline with the bore, the reticle and the viewer. But imperfect alignment of the beam splitter that splits the beam to send the view to the eyepiece will induce parallax error as will misaligned cross hairs.
Think of it this way... a hunter looks through his scope, lines up a deer in the crosshairs, and pulls the trigger. He misses what appeared to be a perfect shot in still air because his eye was 2 mm to the right of the center of the scope. You can adjust the scope for the range you are shooting so that there is no parallax error when you move your head out of alignment slightly.
