METAL BANDSAW, $350, Taber, AB
Tom Kitta
Mine has one two that screws in place of the small guide. Also thick sheet metal but certainly no T slot.
Neither PA nor KMS show the auxiliary table for vertical use.
That is wrong band saw - its 7 x 10 in your link, the correct one is -
"Vertical and horizontal cutting capabilities. "
KMS one is
"Includes table for vertical cutting"
As many others have mentioned, included table is junk. When I sold my BS I actually forgot to give it to the new owner - but no loss, it was just flimsy sheet metal.
Sadly, I have one of those with the flimsy sheet metal table. I'd like to make a new table out of 3/8 or even 1/2 plate aluminium.
But I don't like the tiny screw's that hold it in place.
Did you make a better support system too?
David_R8
Scrapper of metal
Sadly, I have one of those with the flimsy sheet metal table. I'd like to make a new table out of 3/8 or even 1/2 plate aluminum.
One setup I saw, I think from Mark Winquist of Winky's Workshop had a base that clamped into the saw vise with an attached table.
I'll look for it. But my instincts are not happy. The vise on mine is miles from where a table would go. Vise is used in horizontal mode - table is vertical mode.
Tom Kitta
No managed to sell it before I did any changes.
I actually just picked up a small portable bandsaw for cutting small stuff - and it feels like it can do almost anything this machine can do. It has a bit smaller cut range at around 3.5 -- 4". Strange BS length of 52.5 in.
Johnwa
My table is a 3”x3” piece of ⅛” aluminum. It’s small enough that I can leave it in place. It is moderately useful.
Jswain
I used 3/16 or 1/4 steel plate and made it as big as possible that it can stay on when using it normally. The two screws hold it in place fine.
I like his cooling setup
