Elektrishun
This is the 3rd winter where I have been trying to sort out my son's 2010 Mazda 6 "fail to start" issues. What I know so far:
- Starts perfect up until temperature drops to around -25 Celsius
- 2 year old battery tests good
- Alternator tests good
- Terminals are clean
- No parasitic amp draw found
- No other obvious issues related to starting
- Block heater was found to be unplugged from block but is now plugged in and tested working but still fails to start after sitting for a couple of days
- Anti-freeze is good
Known factors that likely contribute to cold starting issues:
- The car will sit without being driven for longer periods of time in the winter (sitting idle in the cold saps some of the starting energy).
- When my son does drive the car it is mostly short trips around the city (not enough to charge the battery).
- the car has a lot of electronic sensors and accessories that add extra load when starting.
We decided the next step was either:
- a battery with higher CCA and reserve
- or an onboard charger/maintainer.
Last time the car failed to start I pulled the battery, charged it up, did a load test/voltage drop test, put it back in, and as usual it started without issue. The car was still sitting in the cold with the block heater plugged in so the only thing that changed was charging the battery. We decided to get a NOCO 2D Genius on-board charger/maintainer.
Checked online and the nearest Canadian Tire had 16...until I got to the store. Now they had zero in stock. I talked to someone at Customer Service about checking the other stores. While they checked another staff member found 1 in the store. Back on track.
Installed the charger/maintainer today (bottom right of image). The most time consuming part was planning and executing the layout which included a short block heater extension cord with multiple outlets. I have it set-up so that the Mazda's block heater cord and NOCO charger cord both plug into the block heater extension cord which is neatly tucked in under the hood out of harms way. The block heater extension cord male end runs out through the lower front grill in the same place where the block heater cord used to exit. Now my son only has to plug-in one cord to power both devices. As well, if he forgets to unplug before driving away he will likely damage the single block heater extension cord end.
This year winter came earlier than usual. I am certain there will be plenty of extreme cold weather yet to come. Before the snow melts we will find out if the charger/maintainer solves the starting issues.
Lastly, clearly some cars are not designed with Canadian winters in mind. My wife owned a Honda Prelude back in the early 90's. Once the Honda was sold it has been all Chevs and Fords. All of them have been good winter starting vehicles when proper maintenance is included. The Mazda is my first experience playing mechanic on an import (the 2nd is my daughter's older Hyundai Tucson which has been a great all around vehicle). There are clues
that some of these cars are not built for Canadian winters.
Clue #1 - the 2010 Mazda doesn't even mention a block heater in their owner's manual. The Canadian dealerships installed them. Compare that to my wife's 2009 Chev Uplander that not only mentions a block heater but that there is a temperature switch in the circuit that closes at -19 Celsius. Designed for cold weather? Yep.
Clue #2 - after searching online for a $200 battery with higher CCA all I could find that "fits" this Mazda is 600 CCA with a reserve of 95. The OEM is 590 CCA with a reserve of 90. I compared that to a 2010 Ford Taurus SE where I found batteries with 850 CCA with a reserve of 130-150 (comparing Mazda's 3.7L V6 to Ford's 3.5L V6). Even the 3.8L V6 Uplander has options up to 850 CCA (not sure what battery is currently installed).
Nonetheless, once the engine fires up I think the Mazda 6 is a great car and a lot of fun to drive.
