Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
www.facebook.com
Somehow or another I must be missing something. How on earth do you use a cylinder square that has an OD that is only polished at the ends? Doesn't that defeat a lot of the purpose?
Is the center smaller, and therefore no polish needed? A question based on wanting to learn rather than trying to teach .... I have never seen one in person before and very little that I do requires much for precision. (Yet I still manage to screw up 50% of the time)Somehow or another I must be missing something. How on earth do you use a cylinder square that has an OD that is only polished at the ends? Doesn't that defeat a lot of the purpose?
That would account for the peened appearance everywhere except the ends.
Inspect the parts big enough to need the 4 x 8 foot, 12" thick granite surface plate that one shop I was in was using as a lunch table!That one Tom posted is 14" high and almost 7" in diameter! maybe 155 pounds. It's huge!
Edit - I see there are two pictures and it is actually hollow. so not 155 pounds. what would one do with a cylinder square this large?
I don't think so Don. They are generally square along the whole length and circumference. That way they can be used to check anything at any height.
I went through my "precision" stage quite a awhile ago, and I've done a fair bit quite demanding precise stuff
I'm thinking about the size of the cylinder, and trying to imagine what type of engine these would be used for?
Precisely.....I don't think I have, or ever will have, a precision phase in my life.
Huh ? Then what are those patch plates in the Ford ?Precisely.....
So far they have been feeble attempts at learning a new craft....Huh ? Then what are those patch plates in the Ford ?
Huh?I'm thinking about the size of the cylinder, and trying to imagine what type of engine these would be used for?
It's way bigger than say a DD15 truck engine, also larger than the ten most common CAT engines, but smaller than a typical locomotive engine.
Seems if your rebuilding engines of that nature, your not sourcing your tools on Facebook.
Huh?
Engine?
You seem to be under some misapprehensions about what a cylinder square is and what it is used for! Not for engine work type cylinders! It IS a cylinder, in shape, the edges of which are at a near perfect 90 degrees (aka: "Square") to the end surfaces.
Used on a surface plate, for inspecting suitably sized parts for their squareness, and in some cases, for setting other inspection equipment to be able to use 'that' equipment to check parts!
They're a cool idea.I'm as "hobby machinist" as it gets. I have yet to see one and the name and shape implied (to me) that is was for checking the squareness of a bored cylinder.
I surrender.
