ChazzC
@Susquatch : get readySHAPER GOOD! WELDER BAD!
I am NOT gunna weld it. NO WELDING! NO NO NO NO NO NO NO NO NO!
Now that’s funny!!!Have you considered welding a socket on the end?
Weld weld weld..... It seems like that's the answer for EVERYTHING!
I have welders! I just don't know how to make a nice weld!
Is the real question then where to get a grinder and rattle can?
You made a tool post! For serious? Pictures?
It doesnt matter what it looks like on the farm...women have been proving that for eons...as long as they get the job done, the farm dont care!!!Then I'll ask you which one you like best and see how many prefer the tool that looks like it has a bad case of slag cancer.
LMAO, this is the funniest post I have seen in a LONG Time, about SWMBO, thank you, it's a great Wake Up, here in Down UnderAlso, apparently you have TIG and know how to use it. Which excludes me from your thinking.
But ya, definitely looking for an excuse to use a shaper.
SWMBO - WTF is that new machine you got?
HWMO - It's a Shaper honey! I needed it to make that custom propeller wrench for our son. You know, the wrench he had to borrow because he couldn't afford one of his own! It's for that new 200ft boat he got for his wife and our grandkids.
SWMBO - OHHHH! That new machine of yours did that! Well it's about time you bought something useful! I'm getting very tired of all the stuff you buy for this stupid farm you know!
HWMO - I know, but don't forget that the farm let's me write off the machine I got to look after our son's family.
SWMBO - OK, I didn't think of all that. It turns me on when you do stuff for the kids you know.
HWMO - Ya, I can be pretty thoughtful when I try.
SWMBO - You wanna?
HWMO - Again? 🙄
So, >>>that<<< is where I Lost my Cell Phone YESTERDAY !!!Um, it's called "under the piles", duh ! 😀
I'm not sure about using a shaper, but to make a square hole in the center of a part, I would suggest drilling an undersized hole and pressing a tapered broach through until it cuts to the final dimension.
I don't have a shaper, but i imagine that you could set it up to hold that kind of tool
unless the square hole is substantially larger than the tool doing the cutting, I think it will be very hard to cut a totally symmetrical shape. And at that size, a tooth pick of HSS seems like a lot of trouble
Using my new tool to put a keyway in the gear I made on the shaper using the gear cutting attachment.
This little project you have planned should give a broad set of lessons for the grandkids, covering several operations.
It seems to be that the biggest problem is that your tool holder is almost certainly too big to fit through the hole that you are trying to make. So You will have to find some way for the tool to stick out far enough and at an angle that it can actually reach in an make a shape through the material.
Don’t have any experience, but wouldn’t it be easier to make it a through hole?Yupper! That right there is the issue. Gunna learn a lot trying to do exactly that.
I don't think it will be too hard though as the 1/2 square hole only needs to be 1/2" deep. In fact it could be shallower but I plan to shoot for the same depth as the width. A 1/4" HSS tool bit held in line longitudinally should work.
Also, not using your shaper, but a new tool: rotary broach in the lathe?
Do you have the shaper yet? What does the tool post look like?
If it is possible to mount a collet there, it might be possible to grind one end of a square HSS round and hold it that way (or use round HSS, and grind a cutting face)
WELDER BAD
I agree - maybe it’s time for you to make rotary broach - just sayingI am NOT gunna weld it. NO WELDING! NO NO NO NO NO NO NO NO NO!
