There is a PPG Refinish product that should work.thats probably a good option for all machine finishing. I'll take a look at that and the Cloverdale Paint epoxy.
Good suggestions folks! Much appreciated.
POR15 (epoxy), is quite durable.
I spent some time looking at the SDS for the Endura 2K 2 part paint. It is pretty nasty stuff, so I take that caution seriously.I've not used it but heard good things about it, seems like a paint that likely won't kill you and is one of toughest.
I've been using PPG line 7 and think its pretty good, but for most machines (except the little Swiss ones) its not worth it paint them; a years worth of chips and coolant and they look the same.
Hardware store cans of metal paint are I believe still enamel. You can mix your own colours, they spray well enough and are reasonably tough after a bit of cure time.
If you are getting into fancy stuff, pay attention to the level of isocyanates present ..... and avoid if are there are any. Its not being a California worry wart, some of them like Imron are potentially deadly depending on a individual's sensitivity and prior exposure. Mask isn't enough as skin absorption happens as well. We have a paint booth at work, full masks and the guys suit up and we still can't spray the higher isocyanate paints. Ministry is all over that stuff
From one of the characters on PM who imo is credible.
I had a sandblasting and painting business in Texas. I normally used a positive preasure clean air mask. One time I got lazy and used just a cartridge filter mask. Just because you don't smell anything in your mask does not mean you are protected. I painted all day and suffered from Methyol Isocyanate poisoning. It nearly killed me. I had severe lung problems, vision problems, headaches and severe depression issues. Nearly ten years later and I still have some lingering lung problems that will never get better.
So if you don't want to lug a oxygen bottle around for a long time be very careful and fully informed of the correct equipment. I was one of the lucky ones in that I only got sick and not dead!
