Looking for a machinist near Aurora Ontario
Shandit66
I have a small project that I need done.
Cut a thread on a 1.5" OD pipe, 6 TPI.
  1. Hollow tubing, 1.5” OD, ½” thick wall
  2. (Hollow, so i can hook up a vacuum system on the non-threaded end
  3. Threaded on the other end - 6 TPI (its an old standard, but the same as my main lathe)
I will provide the adapter, to test the threads
Threads, long enough to grab the adapter
Face the end of the tubing so the adapter sits square
The shaft will fit into a set of pillow blocks, which I have
Its a pretty basic job on a metal lathe - I just dont have one.
If anyone has recommendations in my area (Aurora, Ontario) I would greatly appreciated it!
Barrie, Newmarket, Vaughn, Toronto
Thanks
Olaf
How long is the tube? I have a lathe to do that but I am limited with the pass through diameter to just shy of 1-3/8”. If the tube is not long, there is a chance……
Its 18" long, could be cut down a bit if needed.
I have all the other parts for test fitting
Any help at all, is very much appreciated.
Olaf
I could probably do 18”. I can’t do it for a couple weeks until I am home, but I do have a side job in Aurora when I get back so we could meet then if that works?
I’m glad you found someone Brent.
I saw your post on Cdn Wood Working forum. That spiraled into a Pipe thread tutorial really fast LOL. They mean well, but they can get spun off topic pretty easy.
Yeah - I posted on a few forums. Got a lot of design advise, but not much help. :)
