Tips/Techniques Light cuts and tiny diameters
Tips/Techniques
I've turned brass down to about .030" before just for fun but I tried an aircraft bolt this morning with hss tool. I've only cut a length of about .250" but I'm often amazed at the little tiny bits I can shave off with a sharp edge. I've got it down to .0265" and thinking that's about the limit I can do. I'm going to hone my edge and see what happens. How small should I be able to get? (I know Iength is a factor)
I know there has been a couple of comments in other threads whether it's best to try to "sneak up" on a diameter with little cuts or to take "real" cuts and dial in the diameter right off the bat. After I got the diameter down to .030" I was taking tiny little cuts (sneaking up) but once I got it down to .0195" I thought I would try to take a "real" cut for a distance. I probably was taking a bit too much at once (about .050") as you can hear chatter start, but I thought this video showed that both methods can work.
Ps. Yes I have many other things I SHOULD be doing but sometimes a guy needs to play.
Nice. Maybe photo illusion but how does the inner/outer diameters compare?
Metal toothpicks... YES ...
Wondering about the large Rad on the tool-bit.
Yes if I had started out with the intention of what I ended up doing, I would have left a sharper point on that bit, but I purposely put that radius on it for a nicer finish for other turning. I imagine a sharper/less radius on the bit would have resulted in a better bite on the end making for a less tapered final diameter.
Unless there is some kind of machining or setup constraint, don't be afraid to use tailstock support. This is 303 stainless.
Yes that's a smart idea I didn't even consider. I was kind of just playing around so didn't really plan anything.
@DPittman
That's a very special case you are working on. Most of the sneaking up discussion earlier was about small or big cuts on a normal diameter part - not a tooth pick.
When you are doing something like that with a small final diameter, you are usually much better off taking a bigger cut all the way to final. The reason is support of the final part. When you take a cut like that you need support. A tooth pick provides no support.
I'm not sure I can say this very well, but I'll try.
If you take a big cut leaving just the tooth pick, the cutting is supported by the original OD. The resulting toothpick just stands there afterward and doesn't need to hold any load.
@DPittman
Yes I understand that but I guess I wasn't particularly clear on why I was doing what I was doing. It was just for fun and seeing what I could do.
Joe Pie has a good video showing technique on cutting a very small diameter to specification. I was just seeing "how low I could go".
How about that! Somebody understood my confusing description! Thanks for that. I feel better for trying now!
I think you confused me when you showed and described a shave cut on the needle.
I bet you could go smaller still with the right combination of feeds and cut depth.
I might try it tomorrow just for poop and giggles!
Just so we can compare, what was your initial OD, length, and material?
1/4" aircraft bolt and I initially only cut tiny diameter to 1/4" long.
Air craft bolt! Crap. None of those here. If only tractors could fly.....
Might have to send me one.....
OK, I'll try a regular bolt.
plunging down to diameter and then stepping over has worked for me rather than turning a length to a small dia
