Rauce
For sure, I’ve run mine up 120hz. Never needed to go higher than that, I’m not sure what a max for a general purpose motor is. Usually the specifications are more concerned with the low end.@Rauce that seems to be my line of thought - can the motor be pushed above the 60Hz frequency to get higher speeds and if so, what would be a "safe" maximum setting? Greatly appreciate the comments![]()
I’d be more concerned with the spindle. Say at 120hz you’d be at 1600rpm spindle speed and that chart shows a max of 1100rpm. What can the bearings take?
