Lathe tooling?
I have a Luxcut 1136 lathe made in Taiwan in 1978, and it’s actually a pretty good lathe.
It came with some old tooling and I’m finally getting around to setting the lathe up as perfectly as possible, and upgrade the tooling.
I like HSS tooling on a mid size lathe like this, and I’m thinking of buying a ready ground set of 3/8” HSS bits, and then I will grind custom bits for the specialized stuff I run into. I figured it would be easy to buy a basic pre ground set as a base to start from.
Can anyone recommend a brand that’s decent quality for a set of 3/8” pre ground lathe cutters?
I personally wouldn't buy a set because they are generally poorly ground. I would just buy some decent HSS and grind your own as you need them.
Have a look at this (long) thread on Hobby Machinist for three excellent and very useful shapes.
Models for grinding HSS Lathe Tools
I got a tip before from @Susquatch and normally I will not buy US made anything right now. BUT I do not know chinese supplier of these... HSS insert tools. The convenience of carbide indexable tooling in HSS.
Use T-15 HSS for:
  • Interrupted Cuts
  • Underpowered Spindles
  • Gummy material like stainless, aluminum, and brass
  • Less than rigid setups
Arthur R Warner Company HSS inserts and tooling
We had a thread a couple of years ago that covered similar territory. Still relevant:
I maintain that the steves-workshop page I linked to is the best concise description of grinding HSS lathe tools so far. Grind 3 surfaces and 1 (optional) radius and the tool is done! Just need a basic bench grinder with cheap coarse wheel. The tool will work straight off the grinder but the edges can also be refined (and prolonged) with abrasives.
Despite the impression you might get from the Internet, it is NOT hard to grind HSS lathe tools. Feel free to practise with 3/8" key stock. Set the grinder rest to one of the angles and use a sharpie to draw a guide (on the rest) for the other angle. The angles DON'T have to be perfect to cut--close is good enough. Have at it.
They look like carbide inserts but are tool steel of some kind, HSS probably.
Yes they are HSS inserts. That's AR Warner's claim to fame.
For the biggest bang for your buck just grab some 3/8 HSS blanks and grind them to suit. I have a whole drawer full of HSS in various sizes and shapes. Any shape I want is just minutes at the belt grinder.
