Last weekend’s project, and the first one using the digital readout. Was more milling than turning but it all happened on the lathe.
You made that on your lathe?
Very nicely done. I wimped out and bought my micrometer stop, looking at yours, I really wish I hadn't. That is the wonderful thing about the lathe, it's the one tool in the shop that can do it all.... Just takes a little more planning.@YYCHM yes all on the lathe. The biggest challenge was the keyway. I’m currently looking for a mill but it needs to be the right one.
Thanks @140mower & @6.5 Fan. There’s a lot of experience around here so it’s nice to get a “good job” from everyone. It’s probably just the paint. Hahaha
Side question about knurling... I haven’t done much and I only have one set of wheels for my knurler... I just kind of go for it.
Should a guy be knurling on the lead screw or on the feed bar?
I used the lead screw this time but usually use the feed. It’s a pretty aggressive process and seems like it might be better to do on the feed bar because it has a clutch on it?
@Susquatch I would normally go pretty easy, maybe make a test piece. I made the mistake of watching YouTube first. seemed like most were putting a lot more pressure than I would do or have done, one guy was doing it similar to threading.
the carriage stop...
There are some plans for something similar on a site called Tomstechniques (I think). I don’t usually use plans and went off this picture instead. I used a 1/2-20 thread which works out the same as the one in the picture 0.05” per rev. It probably won’t ever get used as a measuring tool so did bother with much for markings on the dial. Not sure if you noticed the 5 drill marks on the back of the dial I made? With the ball and spring it gives you a “click” every 0.01”.
I hold a view that bump knurlers are unnecessarily hard on everything - the part, the work holder, chucks, centers, bearings. The scissor style knurls are much kinder to the entire setup.
The carriage stop drawings for Tomstechniques and Cogwheel are in the "plans" section here on the site.There are some plans for something similar on a site called Tomstechniques (I think).
Nice job on your carriage stop.
