Lathe: Standard Modern Utilathe 1654
I decided that I want to address the slop that is in the compound feed mechanism. And, yes, I'm currently using a solid tool post setup, so what better time than now to fix the problem.
I have 0.020" backlash. Taking apart the compound, it looks like it has been worked on before. I think the original crossfeed nut was integral with the base of the compound. It looks like it was replaced with a fabricated unit from cold rolled steel, and attached by a screw from the bottom. The threads of the feed screw, 1/2"-10RH acme, are, I think, acceptable. I measured the threads in 4 different places with the 3-wire method, and the pitch diameters were consistent within 0.0015", of each other.
So I will only make a replacement nut from C95400 aluminum bronze. And I will use a tandem tap to do the threads.
