Kurt vise reversed jaws?
Well, Glacern lists 3.125" between holes for their 5" if you measured 3.1" something that seems to confirm. https://www.glacern.com/gsv_550
Same for the Shars 550V - they list 3.125" between the holes https://www.shars.com/5-550v-cnc-milling-machine-vise-0-0004-1 (pretty sure this is a copy of the Glacern who copied someone else...)
but - Shars also has some vises that look alot more like the one you show and they have a far less definitive statement that the holes are 2.99" apart (probably a conversion from 76mm)
If you want hard jaws, most available sets will cost you more than that vise cost new (Glacern are $119 US). I recommend just using some aluminum jaws on it. Make them yourself and be done.
Definitely more than 3", 3.125" is in all likelihood what it is. Well looks like I have another project to add to the list. I will also keep my eye on eBay.
Thanks.
Most Kurt-Style vises have this feature. I made slightly wider (3-1/2" vs. 3-1/8"), taller ( 3" vs. 7/8") jaws for my 3" Kurt-ish vice, and leave them in place on the outside unless I need them on the "normal" location for some reason (that way I always know there they are):
Chaz that is really cool. So much neat stuff in that picture, love the power feed. Vise handle. The index plate. Very cool.
Making your own Talon Grips is interesting but seems a poor use of shop time. I've made hundreds of parts using only one set of grips (still in good shape) so four is apt to be a lifetime supply in the typical home shop.
I skipped through his first video so probably missed a lot but how could anyone make a 35 minute video about turning round stock into small, rectangular, pieces of flat stock?
"Does anyone recognize this brand and suggestions for replacement jaw source?"
I have what looks to be the same vise and it's an older Busy Bee purchase. Mine has the holes to mount the reverse jaws. Thanks for starting this post, I may of never found out this option.
Do you have the base to rotate the vise? If you don't, I have a spare one you are welcome to have.
I made my own Talon grips about 10 or so years ago. IMO they're not that bad to make, and for the price of them, I think it's actually a wash vs buying them if you have some downtime and feel like a fun project. I don't know what the price is now, but back then they were sure proud of them. I'll have to dig through my box later and see if I still have the angle fixture I made for them. I made them from 0.25"x0.5" O1 flat ground, and milled them in strips, the sliced them off. You need a bullnose endmill with I think a 0.03-0.05" corner radius if I remember, it's been a while....
I used them in aluminum jaws. Always wanted to make a hardened steel jaw, but just never got around to it. The aluminum held up well, and I was only using them for 1st op stuff anyway, so it didn't really matter. Never had a part rip out of them, nor one break, and we abused them...
Thanks; can't claim a lot of credit, other than careful shopping: the power feed is from LMS (although I did make the clutch knob - easier to grab than the stock knurled knob - see The Home Shop Machinist Jul-Aug 2023); the vise handle is one of two from Osteg Texas (made to order by Richard - V1 was a little long so he made V2 which fits my 3" LMS vise perfectly; he did them as a test of his CNC programing skills); and the fixture plate was purchased on eBay as a "Stainless Steel Fixture Plate," but it turned out it was a tinned Copper grounding bar: it's flat, has 10-32 tapped holes is a handy size and it was reasonably priced so I'm happy with it.
I did put the V1 Osteg handle to good use on a 4" self-centering vise that I "tuned-up" (and the post following - #8472):
This was before I joined this Group, and I didn't post past projects (I did post it on H-M, but they're having some issues with older posts, so I linked HSM).
I had and sold a BusyBee 6" version, This one although old seems a bit better than the one I sold. I don't recall seeing 5" at BB but they probably do or did sell them. I also have the rotating base that I'm not using, I haven't even taken the time to clean it, not particularly useful for me when you can simply program any angle via the keyboard.
