CA-BC Klondike Lubricants
British Columbia
Type
Shop
My problem, is that for what I do, 1 or 2 Liters would last me a lifetime.
I think that applies to most of us.
I did a bulk buy of vipers venom to share with others. It all went really fast. Some even got shipped west. Hard to beat that stuff for machining ferrous metals on any machine tool (lathe, mill, drill press, shaper, etc etc).
I have no specific experience with that product, but I do use soluble oils for coolant (trim microsol) in the CNC, and have some old cimcool stuff I mix up in spray bottles for milling, and drilling sometimes. I save the more expensive oils for tapping.
Buying bulk coolants isn't "cheap" initially, but in the long run, buying a concentrate like that and mixing your own (can go leaner) will go a lot farther than using specialty oils, tapping fluids, and wd40 for tasks they weren't made for (but will work for). For milling/drilling/turning where you're looking for some lubricity and evaporative cooling, soluble oils will be cheaper in the long run.
I'm no meteorologist but used motor oil or used hydraulic oil sucks at being used for chainsaw bar oil
