jung-415 surface grinder -- Circuit modification
a smile
Lifelong hobby - cold iron
A German grinder will be purchased in 2021. The electronic circuit is old and some minor faults will affect its use. Determined to rearrange the circuit himself.
Primitive appearance
After simple cleaning
Repair the grinding wheel knife
Probably clean
Make yourself a few grinding wheel splints
Let's do static equilibrium
2021_05_05_08_11_IMG_7743.JPG 2021_05_05_08_16_IMG_7752.JPG 2021_05_06_18_32_IMG_7795.JPG
Operating panel
Transform the circuit, increase the frequency converter, transform into PLC control
Almost done -- testing
Add silicone water baffle
According to Google translate from Chinese:
1/ I bought a German grinder in 2021. The electronic circuit is old, and there are some minor problems that will affect the use. Resolve to rewire the wires yourself.
original appearance
2/ After simple cleaning
3/ Repair wheel cutter
4/ probably clean
5/ Make yourself a few grinding wheel cleats
6/ Let's do static balancing
7/ operation panel
8/ Transform the circuit, increase the frequency converter, and change it to PLC control
9/ Almost done - testing
10/ Add silicone water baffle
a smile
original appearance
4/ probably clean
7/ operation panel
Thank you for your patient translation!! It's my oversight. I'm sorry!
Hello @a smile
Interesting posts and work you are doing. Thank you for posting.
Are there metal working social media forums like canadianhobbymetalworkers.com in China?
a smile
Yes, there are some! However, with the strict regulation of speech, there are fewer and fewer forums, and even now the only remaining forums have to be very careful to speak, and the atmosphere of the forum is more and more utilitarian swamping the space for easy and free discussion! So, I chose here!!
