I have two! What’s On your mind? Is it designed?
Can I delete duplicate pictures somehow
I dont think this is exactly what you're thinking of but it might give you some ideas.
It is the toolbit holder for grinding the hss bits for my Diamond tool holder. Its very easy to use and takes care of all the angles necessary.
I can see your idea working and using 3D printing for prototyping but I can see the plastic breaking down quite quickly. Aluminum would work. Do you have all the angles and specs for the concept?
The second one is sort of close. Are you grinding them on a bench grinder? Is your jig angled in two planes?Nope just these two simple bits
Yes and yesThe second one is sort of close. Are you grinding them on a bench grinder? Is your jig angled in two planes?
An easy way of accurately orienting things at angles is just using pins sitting in a drilled hole. You might get a lot more useful setups with different pin/hole combinations on the same aluminum fixture plate. Milling all that material just to get a back stop doesn't really accomplish a lot in my mind. You can slide the cutter along the pins the same as a slot unless its very short. Also most end mills have some kind of radius so your HSS blank may not even butt up against the slot side without a bit of file dressing or relief in the corner.
Then for clamping, something like what DPittman shows looks fine to my eye. As long as you have some way of feeding this assembly into a grinder in light stroking passes vs set & plunge mode,
You drill holes in the aluminum relative to some datum surface & insert dowel pins in there which protrude up a bit. These act as datum stops for your HSS to rest on & accomplish the same thing as your milled relief.
