iPhone for real-time measurements
Arbutus
I thought some folks here may find this interesting, I came across this app for the iPhone which allows the phone to be used to take physical measurements using the phone's sensors.
So far, I have used it for inclination, audio (my dog has a 110dB bark) and vibration monitoring on rotating machinery.
The outputs are raw and its a bit clunky to use, but it might be useful in some situations.
Free from the Apple App Store
Cool, what’s it called?
Sorry I was reading the forum in my phone and I couldn't make out the name.
Here's a link to the developer's page:
I can't really say how they compare, but a while back another member put me onto some similar apps for Android. I have a frequency counter which is cool enough on its own, but there is also a frequency analyser too! Really cool!
Coincidentally, I used the level a few hours ago to set screw holes to clock an auto feed. Levels work, but they don't give you an angle.
Can you elaborate on your application/test?
Coincidentally I've been dealing with a resonant vibration on my mill at a certain RPM. Would it be able to somehow 'visualize' that or detect source strength by holding it in different locations?
Not very scientific! I just laid the iPhone on the mill table and recorded a spectrum at various speeds. Some runs had a flycutter in the chuck to induce vibrations.
There is a better app for visualizing harmonics and modal frequencies though - try (App Store) Vibration Analysis by Dmitriy Kharutskiy.
This is the FFT from the mill at low RPM, with the flycutter mounted, cutting air. Modal frequencies at 20Hz and 37Hz.
