Inside depth mic WTB
Chicken lights
Forum Pony Express Driver
Anyone got an extra one laying around? 0-4” is plenty, nothing crazy needed
Digital or mechanical is fine, I don’t need anything crazy accurate
A flat block (eg 123 block) with the Caliper slide down through the holes or even a plain piece of flat steel can be laid across the two sides and a Caliper used to measure the pocket.
Just subtract the block or plate.
Or zero a digital one at the block/plate thickness.
You can also buy a depth adapter for the Caliper. (or borrow mine).
Caliper Base, Dial Digital Vernier Caliper Stainless Steel Caliper Depth Base Attachment Measuring Stand Attachment 7 x 0.8 x 3cm https://a.co/d/6qd43gT
trlvn
There are a couple available on Kijiji if you happen to be around the area:
Caledon, $60 -
Woodbridge, no specific price -
Chicken lights
I didn’t know they had a caliper base, that’s likely the cheapest option and would work well
Thanks!
Thanks!
They do work well. I'm just a bit worried that your block is too wide between the two asterisks even for the base. You might still need a flat plate of some kind. A 123 block or 126 block would solve that problem. If the measurement is not critical, any flat plate will do.
Or two parallels side by side with a gap between then for the Caliper stick. Bonus if your parallel has a hole in it so you can just use one.
