There are a couple of plates on Printables. Not sure if they're what you need.Yes, on the Bambu X1C. I can try to find the dimensions. The outer diameter is not really important. It can be 8" diameter or so. the inner diameter is 0.829, 0.218 thick. I can drill the three mounting holes off my existing plates. I dont know their circle diameter or size. Drilling them later would be simple enough.
Ideally a plate of 8" diameter with 45, 50, 60,70,80, and 127 patterns.
Some on thingiverse. Might be the same tho.There are a couple of plates on Printables. Not sure if they're what you need.
I've been looking all over the place and haven't found one. I haven't had the time to try to design my own yet. Surely I'm not the only one to need a 127 hole plate.There are a couple of plates on Printables. Not sure if they're what you need.
I'm no expert, but the maximum number of holes in the included plates is 49 according to the manual. Higher numbers of divisions use indirect indexing. Because of the 40:1 ratio of the worm gear, there are 40 divisions for each hole on the dividing plate. So a 16 hole plate can create up to 640 divisions by advancing a single hole at a time. Advancing 2 holes cuts that to 320 divisions. Advancing 5 holes gives 128 divisions (640/5).Does anyone have a .stl of an index plate for a BS-0 dividing head with 127 holes? I could really use one.
BTW, I believe the holes in the factory plates are slightly tapered so that if there is any wear to the pin, it just sits deeper and thus 'slop' in the mechanism is minimized.
127 is a prime number. It can't be indexed without direct indexing off a master, which I could also do, or by using 40 holes of a 127 hole plate per gear tooth.
I want to believe that these systems are better than my assessment of them, but that's hard to realize. I always end up in the same place. The plates are mostly about making the user believe the accuracy is better than it really is. Flex in the arm, the pin slide, the pin fit (which your taper eliminates), and the gearing system all conspire to destroy it. But does it really? Without an accurate precise way to measure the actual output angle, we don't really know.
I have another 127 tooth gear I can direct index from by mounting both to a common mandrel. I just wanted an stl file for a plate.
You waskely wabbit, you done gone down the hole again......Index Plates (dividing head) by samstu
Multiple updates. Physical objects remain untested.4 plates total. 6 inch diameter plates with 1.5 id. Used for 10 inch american made dividing head not the more common 7.5 inch. English (inch) measurements - you may need to scale 2540% for software slicer to convert to correct...www.thingiverse.com
OMG I have to stop now!!
