Think timing will shorten the 5 feet,
The disk is chain driven from the planter tires. Once the vacuum is gone, the seed falls off the disk. So it has to be driven to pick up seed. Hence the unplanted space.
I was thinking I'd just start planting a bit sooner. But then you are double planting the overlap. I think I'm better off with 5 ft unplanted in two rows than double planted on all 11 rows. To some extent the beans fill in the skipped rows in their fight for the sun.
Anyway, the whole idea is to skip the tractor tire rows so you don't drive on plants when you spray a month later, so what is a few more feet of sprayer rows when you already have miles of them? It's nitt picking. If I can fix it fine. If not, I can live with it......
there may already be a vacuum breaker in the system to prevent " over nothing in the system". Is there a gauge to read vacuum pulled? Smaller setups only can pull certain amount until leakage past rotor/vanes makes for no more increase in vacuum.
It's a hydraulically driven vacuum fan. I control the speed of the motor with the tractor SCV to set the max vacuum with the disks full of seeds. When you first start, all 5he plates are empty with no seeds in them. They leak like a boat made of fence wire. So there is virtually no vacuum. As the plates fill up, the vacuum climbs until it reaches the set point of the vacuum motor.
There is a large magnehelic pressure gauge on the vacuum manifold. I just dial in the pressure I want by looking at it.
Would think a safety of some kind, or could crush lines in a run away, ( not sure how, but!).
Remember the apple juice can under the hood, just one tap with wrench.
There is no real danger of over pressure like that. It never gets that high. The gauge maximum is only 15 inches of water and for most seed I run it between 5 and 10.
Too high a pressure sucks the seeds right through the plate holes which reduces the pressure. Too low and they fall off before they reach the drop point. So the pressure has to be fine tuned for the seed size and shape.
Turning the vacuum off on two rows would mean very little. Turning them all off would raise the pressure beyond ideal but not enough to damage anything. The worst case is all off but one. That could be too much vacuum... I'm thinking that a calibrated drilled orifice in the solenoid could simulate the full air leakage of a working row and not affect the over all pressure at all. If the orifice is closed during regular operation, it has no effect on an open valve. It would only work when the valve is closed.
