I suck.
Both Monica and I think YOU SUCK!
Cigar anyone?
Dang I like sucking.
Chris was a big help making the loading go smoothly. The lathe was winched off the loading dock on to a Totem Towing tilt deck tow truck. Slick. The driver did a great job jiggling the skid off the deck onto my shop floor. Probably tied the truck up for 3 hours total and I was billed $305, a total bargain.
Not to be superstitious but things often happen in threes. A couple of buildings over from the machine shop at the University they're putting up a new building. They have a massive huge foundation almost up to grade. Sprouting up out of the concrete is probably one of the largest rebar structures I've ever seen and I have seen quite a few. Over the weekend, for some reason it all fell over. Ooops.
Number two was this morning at the machine shop. The shop auctioned of a mill at the same time as my lathe. They loaded it onto a tandem axle, tilt deck pick up truck style trailer. Just after they landed it on the trailer they realized that they hadn't secured the tilt lock and over she went. Luckily the chain block caught it and they managed to save the situation.
Luckily for me the streak ended at two.
I’m glad that you totally suck big time!!! Looks like a lovely lathe!
I'm really going to enjoy it. I'm having to move every machine I have to get it where it has to go. Got it through the outer shop and into the shop proper after work today. Hopefully, 1 maybe 2 days and I can start looking at the power supply.
And the reinforcing grid system is at:... The UBC school of engineering materials strength testing and building earthquake resistance engineering!
How embarasing
"Able to resist forces encountered during erection"
Very lucky nobody got killed.
Oh no, I really suck. Properly like.
I got the Meuser lathe auctioned at UVic. First auction and I won, it's easy. Eight seconds remaining and $22.90 more than the next guy.
I went and looked at the lathe on Monday and it's a beaut. UVic bought it in 1971 (I have all the paperwork) for their science departments collaboration with the Triumph project, the cyclatron at UBC. As I understand it this was basically a one man shop. He passed away a few years back and the shop just fell idle. Now the university wants to convert the space to another purpose and so the lathe and the mill are going.
There is another shop there and they are doing Triumph stuff and and other UVic stuff. Chris, who handled the sale runs the show. He would have liked to have this lathe for his shop but it doesn't have a foot brake so it's not allowed, not safe. He showed me the lathe and gave me the background on it and then I got the shop tour. Two BP sort of mills, a Chineesium lathe, a clapped out Colchester and a small Haas lathe and mill. Very clean and very interesting looking projects.
So for pictures, here you go,
This cart has seven boxes, two pails of oil and one of the steady rests. I picked this up today and will be picking the lathe up on Monday. As a rough inventory the boxes contain the following,
1 6" 3-Jaw chuck,
1 8" 3-Jaw chuck,
1 8" 4 jaw chuck,
1 14" 4 jaw/face plate chuck,
1 8" drive plate,
1 tool post for ball turning,
1 spare motor drive pulley,
4 chuck keys,
2 dead centers,
1 live center,
1 3 3/4" live cone center,
1 5" live cone center,
1 lantern toolpost with 5 tool holders,
1 drill chuck,
1 change gear (high speed ?),
6 drive dogs,
3 center drills,
9 boring bars,
2 insert tool holders,
6 Enco multifix tool holders,
6 pin wrenches,
1 solid tool post for large boring bars,
Oodles of original wrenches and hex keys,
2 steady rests (8" and 4" ?),
1 follow rest,
1 solid adjustable carriage stop,
1 each left and right micrometer carriage drive release dogs,
1 oiler,
and a few things I have no clue about and a bunch of high speed steel.
More to come when I get the lathe.
I suck, do I have a seconder ?
What!..no taper atattcment ??!
I removed it.
No hard feelings. Just as well
The Meuser has landed. Right way up and everything at that. Note to self, don't do that again, at least not till you make a toe jack.
Hopefully I'll be adding another 140 or so square feet to the shop this summer so I'll get to move it all again.
So now I have to get back to my sweetie designated hobby but with a bit of luck I'll get a few hours to clean, power and fiddle a bit.
Chips at last. Why didn't any of you warn me that bigger lathes make bigger, hotter chips ? Bastards.
When previewing the lathe it was pointed out that the front way wipers were missing and the holes for their mounting were plugged. There had been some mystery attachment in that location which was also awol. So first task was to to make replacements. The plugs were flush so I ended up drilling a small hole in the end and using an extractor to unscrew them. Luckily I had a flexible 12" drill bit so I was able to drill without removing the carriage from the machine.
Arbutus kindly provided some felt for the wipers. The Meuser has way guards that afix to the wipers.
So the first chips were from a mystery honey hobby part, well two actually. They are made from a section of angle iron and they needed a 2" counter bore on the inside of the angle. First try was on the rotary table but there wasn't enough clearance for the ER40 collet chuck and no endmill long and large enough. Second try was with the boring head but my boring bars that are long enough to reach just don't have the rigidity. Third try was in the Meuser. The bars in the multi fix could reach but I'd have to alter the shape of part to get clearance over the saddle. Oh but wait a moment, one of the many accessories that came with the lathe was a large boring bar holder that mounts in place of the tool post. The 1 1/8" boring bar reached in easily, woo hoo, easy peasy.
Happy times.
One odd thing is with the motor. I believe that the correct operation is to lift the clutch lever up for normal spindle direction and push down for reverse rotation. This lathe works the opposite of that. It's not really an issue for me as I am not accustomed to using this type of control. I reversed two of wires which made everything operate "properly" except the oil pump does not work in that direction. Perhaps the up and down is not standardized ? Comments ?
In my limited experience, down is forward, up is reverse. So I think it was right as you got it.
On my Leblond up is forwards and down is reverse (there is a gate on the lever to lock out reverse unless you move it aside).
