How to make a 5/16" bore with this boring bar?
eotrfish
I recently purchased this boring bar from KBC. Note that the minimum bore is specified as 5/16"
Screenshot 2022-05-26 at 13-36-51 KBC 1_2SH 5_16BORE LONG C2 BORING BAR 1-4522-B5L KBC Tools ...webp
I've asked KBC to explain how I would create a 8mm (0.315") bore with this bar but no response so far.
If you purchased in store they should exchange it or give a refund. They should have an issue with it. If it was ordered and sent it might take a little longer.
I think you caught KBC with an incorrect size ‘spec’.
It is impossible to bore 0.3125“ with a tool that is 0.3275”.
Am I missing something ?
No - you're not missing anything. I had the same thought.
Heard back from KBC. They checked stock and all of the bars spec'd as 5/16" min. bore are oversize. Now they are checking their stock back east.
It's not a big deal since I found a miniature Chinesium 6mm boring bar in my stash - mission accomplished. It just pisses me off that the QC dept let this slip by.
I would just grind the profile of the right side to reduce the width to less than .300
I did grind the backside of one that I already had but it wasn't long enough to clear an upset on the part.
Like John says, grind to get what you need. With that style BB you can expect to grind it. KBC was kind enough to give you a little extra material, and didn’t charge you for it.
Hopefully yours are an improvement of the import brazed boring cutters I had. It was many moons ago but the geometry was so messed up you could not even rotate the shank relative to boring head axis to get the proper cutting tool angle. I kept them just for occasional use in lathe tool post but even that was a clumsy setup without a flat reference on the shank. One of the YouTubers had a whole episode on 'remediating' them. But that's a dated generalization, maybe they are better now.
Borite has a line of cobalt cutters in nominal shank ODs which are pretty decent & I think you can get them individually from KBC.
Borite if KBC was willing to do partial exchange, but I didn't check min diameter
Somewhat related to small bores FWIW. I bought some of these carbide cutters form Ali along with a matching (6mm shank) tool holder. They cut really nice. So far used the straight boring & internal groove, the internal thread will be next. Good value compared to USA counterparts. I've only used these in lathe thus far but I don't see why an adapter couldn't be made for boring head socket.
The oversize KBC bar was actually a blessing in disguise. It still was not long enough to clear the upset on the part so I had to go search in "other stuff" drawers. I found a 12mm x 6mm tool holder and boring bar that worked perfectly. I used the 12mm x 6mm tool holder directly in my boring head. Since the holder has two opposing flats it is plenty secure for boring 6061. I didn't bother shimming it to 1/2" dia.
I have the tool holders in 4, 5, and 6mm with a selection of boring, grooving and trepanning tools. The internal grooving tool is sweet for 1mm cross section o-rings. I would highly recommend these Ali tools and holders for small precision work.
