Megar arc 5040dd
I am off to get my new to me Modern ZX45 milling machine tomorrow and that brings up my question. How much should I ask for my old mill? It is a horizontal mill with vertical head. Table size is 29 7/8" x 6 5/8", X axis travel is 18.7", Y axis travel is 6.8", knee travel is 11.65". It also has power feed in the X direction. The vertical spindle is MT3 and has a 3/4 hp 3 phase motor powered by a vfd 230 volt input power. The horizontal spindle is I believe iso 30 taper but I could be wrong. It is driven by a 2 hp single phase motor 115 volt input. speed is controlled by step pulleys and had back gears. All the ways are dove tail and have adjustable gibs. It comes with an ER collet chuck and set of collets, horizontal arbour, as well as the other tool holder and fixture plate shown. There is also an overarm support bushing (not sure if that's the proper term) that is not shown.
I bought this mill almost 7 years ago and it has worked great for me. I have never actually set it up or used it for horizontal milling before. I did not build it but I did add the DRO and changed the vertical drive so I could have variable speeds. I just finished changing the vertical motor over the other day right before I found a new mill.
The only reason I am buying a new mill is I want to have a quill. I will give is a good cleaning and hope to post it on kijiji this weekend. If you have any questions I will answer them as best I can.
So how much should I ask for it? I am located in Saskatchewan where there never seems to be many mills for sale (hence why I am driving 5 hours to Edmonton to get one tomorrow)
