Honey the house is sinking…
MashingMetal
@jorogi Asked about my what’s wrong with my house. It all started with our 85 year old house a couple years ago, come August things were shifting, doors not closing properly cracks opening up. We are on full gray clay here on the escarpment and it expands and contracts a great deal. Lots of people have needed basement work around here in the last few years. Dryer summers? Building in the area? Who knows.
After excavating down to the foundation around the house there needed some urgent work to be done, blocks and foundations were cracked from all the shifting and screw piles needed to be installed to stabilize the house. I was able to take care of the blocks, and foundation though underpinning, re pouring concrete in the walls.
The screw piles had to be installed around the outside with a 12 wide bracket underneath the foundation by certified installer. About every 5ft, these things are massive and go 5ft into the ground with a 12” screw head Then I could lift and level the house back into place. It is pretty simple just tightening 2” bolts. Then pour concrete to seal them in place and prevent water intrusion.
Thankfully I am almost done now and can go back into enjoying the shop.
A few more. They have to cut out sections of the foundation to get the brackets right under the load of the house.
Oh my gosh, what a nightmare.
Years ago a friends parents house had similar issues but just with the one end of the house. Luckily for them the solution was to kill a 10" trunked cedar tree 150' from that end of the house. With the next rainy season everything "floated" back to where it started.
Enjoy your return to your shop.
Yikes!!!
I'm slab on grade, 250 yards from the mouth of the Fraser River, 3 yards above nominal sea level. Which today, due to king tides and heavy rain, is just about 1 yard below the current river water level. So no concern about sinking, more worried about floating away.
Interesting equipment and process. I’m glad it could be fixed! Good pictures thank you.
With that limitless supply of clay, what are you wasting your time with metal-working and woodworking? Just throw a shovelful of that stuff on a potter's wheel and you're in business!!
