Hi,
Hopefully the picture will explain alot.
I'm planning on mounting electric die grinder to tool post similarly as many other have. The mounting collar is a piece of shaft that is yet to be bored out. The shaft in the centre now is just an arbor for turning OD. I plan on mounting some flat 1/2" in milled shaft that will then clamp in tool holder on qctp. The problem is my milled slot is not perfectly in line with the axis of the grinder. I have to do the milling on my home made milling attachment for my little lathe and is it all less than ideal. I included a picture of my set up for giggles.
Will the off axis alignment of the grinder be a serious problem or will simple stone dressing bring things back to where they should be?
