Hoglet V twin
Ken Mach
Wondering if anyone has built a Hoglet engine? I have questions regarding what ignition you used?
There's a web site on that sort of stuff.
Hi Ken. Are you on HMEM? The engine gets discussed there.
Learn turning with Andrew Whale has a complete documentary 16 parts I belive showing techniques and changes he made. Here’s #1.
Yes I am on that site ….I guess what I’m trying to find is a made in Canada solution …a pipe dream probably. There was a fellow in the US that made ignitions specifically for the Hoglet he retired.
Unfortunately I wont be much help. This outfit sells spark ignition modules, plugs, accessories... for multi-cylinder engines. More orientated to RC models though, so some cost premium for airborne components that have to be compact & low weight etc. And also USA based & I suspect spendy compared to some of the shop made solutions. Good luck. Hope to see a video when its running,
You can run what is called waste spark ignition. One sensor at TDC and one at the max advance point on the crankshaft. You fire both plugs if the engine is running an exhaust stroke at the same time as the compression stroke on the other cylinder. (Not all twins run symmetrically like that).
There are dual and quad ignition coils designed for that. Two spark plug high voltage outputs and a low voltage in.
You probably don't have to go with CDI like we did on this one.
John
Ken, what ignition system do you have hooked up now? Is it giving problems or you are looking to change for some other reason?
Also, I'm interested in your carb. It looks like off an RC nitro vehicle? I discovered after I got some carb prospects for my radial that car carbs might be as good, if not better choice. Apparently some have inserts to vary venturi throat size? Is it a slide valve or rotating barrel?
I've been watching the videos by Andrew Whale as I fall down yet another rabbit hole. Question for @Ken Mach
How did you make your cam shaft. Did you use the boring bar approach or a different technique? What material did you use?
Boring bar method I built it from drill rod
The reason I ask is I was given a Craftsman Garden tractor with a 17.5HP B&S engine with a duff camshaft. Likely the carb needs a good going over too.
Long story short is the camshaft has centrifugal weight that releases compression when the cam is not turning quickly. That makes possible for the dinky starter and small battery to turn the engine over fast enough so when the weight flys out the compression happens and the engine fires.
The defective cam shaft surfaces as motor won't turn over. Hold rubber inner tube piece over carb inlet to prevent any air ingestion and engine hasn't got anything to compress so it turns over fast enough. Remove rubber flap and engine starts.
All the videos out there show the same issue. CAM is anywhere from $25 to real B&S for $150. Except B&S not available until end November. Far east clones often fail after several hours running. Not worth the effort to tear down and rebuild with unreliable CAM. So I've been thinking about making my own.
I have the tools...
I have the tools...
I wouldn’t make a cam shaft for your engine from drill rod I’d look at 4140 htsr or something of that nature And it should be hardened and ground. Keep in mind that the Hoglet engine is not designed for long runs or to drive anything it’s a display engine basically.
It’s an ignition designed for model aircraft engine an Excel …..it will fire with a strong magnet but this Engine will only allow for a very small magnet not strong enough to trip the hall sensor. I tried a combination of different magnets and hall sensors with no luck, i parked the engine about a year ago out of frustration but it’s time to tackle the problem and finish the project.
The carb is an RC carb as well I bought it on Amazon sorry I can’t remember the details but I believe it has a .250 bore larger ones
were available when I was looking.
Lee Valley Tools has some small very powerful magnets. I've been able to trip a hall sensor with those.
You have to watch out for magnet polarity as in the sensor is only sensitive to either North or South. The side of the sensor is also critical for best operation.
This is how mine is mounted inside the 3D printed holder with the pull up resistor and LED to show activation. I filled that with void epoxy to keep the wires in the right place.
Here is the sensor tripping as the magnet rotates around.
And you can see here there is plenty of space to the sensor and the magnet is not that big.
I believe the one I'm using is the
Item 99K3101, 1/4" × 1/10" Rare-Earth Magnet
