ersatz engineer
I get to post this, as We left John's phone back at his house. He found this bargoon for his shop while visiting in Kewlona... This is the answer to the question about what packs the biggest punch? It weights 1 tonne and is hand operated!
It arrived in Calgary last week, but we had to get Ichibod II, the 3 ton 8 foot high engine hoist set up and make room for the new addition. We moved the fly press and finished off some projects to make room. Here it is, just after liftoff from the truck bed:
Before anyone gets too jammy about using ratchet straps for a lift, the spine is actually supported witha 20,000 lb poly strap, the ratchets are for setting the tilt left/right. Here's the crown just before driving the truck away.
The lighter end was supported by 2 - 5 ton nylon straps sewn into a loop. Here's a picture at touchdown, and not too bad a look at the crane:
Can't wait until we get to punching holes in 1/4" plate!
![PunchPress1.jpg PunchPress1.jpg](/data/attachments/51/51511-9566938522806a8f60ca2034753bc730.jpg)
![The Lift.jpg The Lift.jpg](/data/attachments/51/51515-d9476448a8a08df17e67692db2d09e4b.jpg)
![Overkill.jpg Overkill.jpg](/data/attachments/51/51516-57c4320bc8f851edbfccff236cedef1b.jpg)
![Touchdown.jpg Touchdown.jpg](/data/attachments/51/51517-036acf59c8d21670270e7ef19cf71575.jpg)
